Need help with a 4th 0rder - Car Audio Classifieds!
Old 07-15-2010, 02:52 PM
KAPONE.SS's Avatar
0/11 ssssss484
Default Need help with a 4th 0rder
I am planning on buying 2 18" LVL 5's and want to try them in a 4th order. Has any one tried it ? If so what did you think? Also what specs would work good. I really just needthe sealed vol., ported vol., and tuning of ported. I would like a pretty low passband. So if anyone could help. Thank you ahead of time.
Rebuilding.......
Old 07-15-2010, 03:02 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
well. I looked into doing the same setup.
you want about 3 cubes sealed per 18 and about 6-7 cubes ported, and if you want to kill the lows tune around 42 htz to 40 htz. anything less than that and its going to give you problems with upper bass ranges, and sound like crap.
also what vehicle? and you want to give yourself like 180 sq inches of port for good bass response!
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 10-07-2010, 07:04 PM
KAPONE.SS's Avatar
0/11 ssssss484
HOB it is a 96 Impala SS.
Alright now that I have the subs trying to get some more input on this. I have 22ft3 as of right now. I can probably get another couple cuft. more by glassing the box into the rest of the trunk. I already subtracted all materials. I really like the lows looking to kill from high 20hz up. If needed I will add some more speakers to pick up the gap from BP to mids(maybe sealed 8's). Any help would be great.
Rebuilding.......
Old 10-08-2010, 11:00 AM
I'm F*CKIN Sexy!
0/11 sssss2132
So are you doing a trunk build? N you have 24 cubes? That's Prety big for a trunk.... unless you build in the trunk build. Even then
Sealed 152.9
Outlaw 156.6
Old 10-08-2010, 11:15 AM
LivinLoud08's Avatar
0/11 sssss1318
interesting. i plan on doing the same type of build, except with the neo 18s and alot more room lol. can't help on the box though bc im not designing it. subscribed to see how it works out for you.
sold to: willie3719, VanOn26s, papito,ralphysounds,ingramk03, BaseHead, Luis Mendez, davidforbus, RustyWCA, alviso913
That's right. And I walk the walk... no reservations here. If I offended someone, oh well, never said I was nice, just good.
Old 10-08-2010, 11:48 AM
KAPONE.SS's Avatar
0/11 ssssss484
yeah it is a huge trunk.
^^^^This is the box I have in there now. Plan removing the stained piece and build off that. With Birch for all sides,internal framing and top. Then Glassing the entire bottom. Glassing the bottom adds alot of space.
Rebuilding.......
Old 10-14-2010, 09:46 PM
KAPONE.SS's Avatar
0/11 ssssss484
bueller..................bueller........bueller
Rebuilding.......
