should I do some bracing? - Car Audio Classifieds!
Old 07-28-2010, 04:57 AM
0/11 ssssss538
Default should I do some bracing?
I'm running two 12's on 4k rms. 3.81cuft tuned to 32.09hz. I did a double baffle on top. Subs up port back. Just finished putting everything together.
Wondering if I should add a wooden dowel or something. Should it be fine like this?
Head Unit: Pioneer Premier 880PRS
Subs: 2 Custom Ssackett 12's DC LVL5 Softparts
Sub Amp: Crossfire VR4000D Highs Setup: 8 6.5" Powerbass 4XL'S & 8 Crescendo XST2's. Highs amp: Two Crescendo 1000c4's. Electrical: XS Power D5100 & D3100 in the rear
Old 07-28-2010, 10:14 AM
0/11 sssss5305
box dimensions would help.
I try to have some sort of bracing every 12-16", whether it be simple strap bracing or a window brace...
Old 07-28-2010, 07:10 PM
0/11 ssssss538
Old 07-28-2010, 07:29 PM
0/11 sssss1943
You need something going up and down between the subs atleast. Id add one from front to back in the middle of the panel too.
Old 07-28-2010, 07:44 PM
0/11 sssss5305
window brace between the subs would tie front/back/top/bottom together...
Old 07-28-2010, 07:54 PM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
those are very strong from what u told me and a great idea.
u will have structural rigidity out the ass with them thats what mlstrass is doing with my 4th order now.
Old 07-28-2010, 07:56 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
sounds noobish, but id like to know how a window brace is made
is it just a rectangle routed out?
or 4 peices together to support or some ish?
92 Ranger Walkthrough
(Under Construction)
Old 07-28-2010, 08:08 PM
30Hz
0/11 sssss6601
yer cool howie its not noobish my man
this is my 4th order and there is the window bracing in the sealed portion of the box.
Old 07-28-2010, 08:09 PM
rectangle with center cut out
I hate bracing
Old 07-28-2010, 08:18 PM
TNJ
0/11 sssss7882
no such thing as noob questions, only noob answers
Box bracing resko1 General Car Audio Discussion & Questions 7 10-07-2009 04:00 PM
How to: Spline bracing SPL Guru Tutorials & Quick References 2 10-13-2008 12:48 PM
