Trying to design a 4th order for a Rockford P3 - Car Audio Classifieds!
Old 07-30-2010, 10:22 PM
0/11 ssssss168
Default Trying to design a 4th order for a Rockford P3
So I am trying to find out as much info as I can about building a 4th order bandpass. I have built plenty of sealed and slot ports, now I want to try something a little more difficult.
I understand how a 4th order works, but I dont understand how to design them. Right now we are using a P3 in a slot port, and its tuned way too high for our liking. The goal is to build a 4th order that will play good in the lower bass notes such as "Late Night Tip", "Juicebox", etc. However we dont want to obtain a fair amount of SQ and not drown out above the really deep tones.
I am open to any links, suggestions, anything that will help, Im trying to get this designed tonight and built tomorrow.
1997 Dodge Neon Coupe
Head Unit - Cheap Sony w/ AUX
Front Stage - Diamond Audio 6" Components
Rear Stage - Stock
Wiring - Knukonceptz 1/0
Sub Amp - Memphis 500 class D
Sub Stage - (2) 12" Diamond Audio D3 Ported
Old 07-30-2010, 10:26 PM
0/11 ssssss714
what size is the sub?
Old 07-30-2010, 10:27 PM
0/11 ssssss168
Sorry...its a 12" dual 2..thought I mentioned that
Rear Stage - Stock
Old 07-30-2010, 10:49 PM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
from what ive read and seen there not hard to mess up and they will sounds like garbage.
if the sealed portion is given the right air space then ran thought a program it will tell u the cut offs and freq curves, it will drop low as hell
mine has a wide freq range from 30hz up to mid 60s. with a tuning of 47hz.
and SQ out a bandpass i dont know how welll that will work there generally ment to be loud and boomy and move huge amounts of air. thats the 5 that ive seen and herd b4.
Old 07-30-2010, 10:53 PM
0/11 ssssss168
Im not trying to get McIntosh or Paradigm SQ out of a bandpass lol, I just dont want it to sound like a dying giraffe lol.
That sounds like the freq range im looking for, maybe I should shoot for 47hz. DO you use reccomended specs for volume in each chamber or no?
Rear Stage - Stock
Old 07-30-2010, 11:01 PM
30Hz
0/11 sssss6601
i didnt do mine i had F3M4 do one and AMI creations do another. from what AMI explained to me about what he did with the air space.
u can go smaller in the sealed portion than recommended since u will have the sub firing into the front ported chamber.
F3M4 design
AMI design
Old 07-30-2010, 11:15 PM
0/11 ssssss168
Damn thats hella impressive...mine wont be nearly that intricate lol...what about the ported chamber?
Rear Stage - Stock
Old 07-30-2010, 11:17 PM
0/11 ssssss168
This is one I designed just winging it for my Memphis subs. I was also wondering if it would be louder ported to the back or the driver side? Its going in a hatch golf just like mine
Rear Stage - Stock
Old 07-30-2010, 11:24 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
F3M4 design
AMI design
#2 ftw
TeamGG
Team D.O.A.
30Hz
0/11 sssss6601
to the ear it would be louder back. the drivers side is best for metering.
dont look like a bad design u just need to get the number between the sealed and ported good.
6th order design J&T DESIGNS Build Logs 34 07-15-2010 07:59 PM
2 4th Order 10s D4 GearGuy2001 Wanting to Buy (WTB) 10 07-05-2010 09:31 AM
what we need to order nuboot Team Teamless 19 04-27-2010 02:00 PM
4th Order Help. SpeakerBox General Car Audio Discussion & Questions 4 02-08-2010 03:41 PM
