RE 18 MT enclosure advice - Car Audio Classifieds!
Old 08-01-2010, 05:04 PM
Silver-N-black's Avatar
0/11 sssss3544
Default RE 18 MT enclosure advice
I just picked up a 18' RE MT. Its going to replace my two 15's XXX. What should i tune the box too? Looking sql I know these subs are spl subs. How big or small should i make the box? Sub is going to be power by a RD 3250.1. Any advice?
Old 08-01-2010, 05:40 PM
97maxima's Avatar
Loud Trunk?
0/11 sssss1812
id go 5-7 cubes net. Ive had good luck with mine tuned to [email protected] ft. a buddy of mine runs his 15s tuned down to like 26 or 28hz but i wouldnt go below 32 since its in the subs nature to be higher tuned for spl use
Direct Sound Solutions-Taramps-DC Power-Team Loud Trunks
Refs:too many to list
Old 09-29-2010, 06:26 PM
0/11 sssss3544
bump anyone else? sub is going into a Avalanche.
Old 09-29-2010, 06:32 PM
AlanHall's Avatar
0/11 sssss1043
i like MT 18s in 5.5 plus port. about 12inches per cube.. tuned around 36hz ... have had great luck with this set up. after trying larger lower tuned set ups with not near as good results.
Alan Hall -618 791 5108
**Tantric Sounds **
**New image motoring** b2 audio**Tantric sounds**
2011 trunk 0-1k champion 158.8- 2010 trunk 1001+ champion 2012 UsacI trunk 1000+ champion 160.4
Old 09-29-2010, 11:11 PM
18inchjeepin's Avatar
0/11 sssss1931
Feedback Score: 37 reviews
I liked one of mine in about 6 subes, it got down
I had a pair in 6.5 and it did ok on the meter but was very peaky
Silver HHR
TEAM SOUNDSTREAM
XS Power D3100 with Toolmaker blocks
Alpine 9884-> Soundstream RUB4.600-> Soundstream SST-05 tweets-> Soundstream 804N 8" neo mids
A-pipe mini 1500-> pair Sundown SA15's -> 4th order wall
Old 10-11-2010, 01:55 PM
0/11 sssss3544
So it looks like 5.5-6 is the answer tuned 35hz. Anyone else?
Old 10-12-2010, 01:34 AM
0/11 sssss5305
Did one for Sleepy a few years back. Was around 8.5net tuned to 35Hz. Killed the lows and did around 147+ @38Hz. Very solid daily set up...
05 XXX15 enclosure advice 1ndatrunk Enclosure Discussion & Design Construction Help 7 08-07-2010 12:28 PM
need btl advice joselito318 General Car Audio Discussion & Questions 8 06-08-2010 02:47 PM
Need a bit of advice madmat Off Topic Chat 17 02-01-2010 11:23 PM
Enclosure Build: maintrain's home enclosure Pioneer~Saturn Build Logs 80 01-19-2010 05:32 PM
Advice. rdaudioman1256 General Car Audio Discussion & Questions 11 11-13-2008 06:31 AM
