Could you make a box for 12s that could be easily replaced for 18s later? - Car Audio Classifieds!
Old 01-07-2009, 08:03 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Default Could you make a box for 12s that could be easily replaced for 18s later?
like a baffle switch? Would it sound terrible?
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 01-07-2009, 08:06 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
2 12s only require like 4-5cubes. 18s require like 14-15 cubes alone.
1 18 wouldnt breath in a 4 cubes box.
92 Ranger Walkthrough
(Under Construction)
Old 01-07-2009, 08:08 PM
Prohibited Sellers/Buyers
0/11 ssssss327
they don't NEED that big of a box.
I've done 18s before in 4.5/5 cubes and they work fine and meter louder then most of these installs you see with 18s in gigantic enclosures.
I'd rather have a small enclosure with less impedence rise and tune it lower instead of a stupidly big enclosure with impedence rise through the roof...that requires a gigantor port.
but to answer the question....12s will sound like a wet ***** fart in 4-5 cubes each...so you CAN build it...but it would sound horrible.
You can build a box for like 30 bucks man...don't be cheap!
Old 01-07-2009, 08:20 PM
0/11 sssss3638
why not build something like a t-line for the 12's that way the ENTIRE box is big enough. then when u switch to the 18's take out all the un-needed port walls from the t-line and change the baffle?
Old 01-07-2009, 08:22 PM
0/11 sssss3784
okay.
empty trunk
DC Power 270xp
.... so far
Old 01-07-2009, 08:34 PM
0/11 sssss3784
probably will just make 2 boxes
empty trunk
DC Power 270xp
.... so far
Old 01-07-2009, 08:58 PM
make a removable baffle with a 4ft box attached
Old 01-07-2009, 09:24 PM
allout13's Avatar
0/11 ssssss822
maybe if you were going from 2 12 to 1 18...
just curious, what are you planning on doing?
Old 01-07-2009, 09:28 PM
Jbgabriel's Avatar
0/11 sssssss99
I thought the smaller the box, the higher the rise, which is why you can run more power with a smaller box. I could be wrong...
1999 f150
Current Setup:
Headunit: Premier 780-mp
Front: Powerbass SC-6
Front Amp: Boss 150wrms x 2
Substage:
Sub Amp: Autotek MM3000.1
Old 01-08-2009, 08:37 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Technically you could do it, just fill the box with extra pieces of wood till it's time to throw the 18's in.
My Car, My Ears.
Is this box even possible to make? Pictures! BassikInstincts Enclosure Discussion & Design Construction Help 39 01-06-2009 06:39 PM
someone needs to make a .gif of this canyouhearmatt Off Topic Chat 18 12-19-2008 06:05 AM
help me make a decision... RidnClean General Car Audio Discussion & Questions 9 12-04-2008 10:56 AM
Can anyone make me a 3-d view splvictim20 General Car Audio Discussion & Questions 13 10-28-2008 01:03 AM
Videos that make you LOL Patrick Simmons Off Topic Chat 2 08-01-2008 03:28 PM
