help with box - Car Audio Classifieds!
Old 08-02-2010, 03:32 PM
Ego Crusher
0/11 sssss1834
Default help with box
I was on ROE and was given this box design for a dd 3512 the design is great and all but I want to add 45's in the corners, a kerfed port and countersink the sub could someone help me out please.
2.5 Cuft @ 33 Hz (Pics follow)
External Dimensions: 20 Deep x 24.1 Wide x 14.5 High
Internal Dimensions: 18.5 Deep x 22.6 Wide x 14.5 High
Cutting List
- Top; 24.1 Wide x 20 Deep
- Bottom; 24.1 Wide x 20 Deep
- Front; 13 High x 20.6 Wide
- Back; 13 High x 22.6 Wide
- Side; 20 Deep x 13 High
- Port Part 1; 16.5 Long x 13 high
- Port Part 2; 1.42 Long x 13 high
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 08-02-2010, 03:44 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
wft, 20.6, 1.42... stupid measurements if u ask me, stick to 1/4" increments at the smallest
that box is not correct at all for a DD3512, not enough port area and stupid dimensions
45s are simple, go buy 3/4 cornerround or inverted roundover from lowes/menards/home depot... $2-3 and very simple... they barely affect tuning and volume if kept small
kerfs are over-rated unless u do it on the inside too, a simple 3/4" roundover bit on a plunge router on all port pieces is likely just as effective at reducing turbulence and airspeed at terminus
to countersink, either add an internal baffle which is super easy but takes up some volume and has to be added before finishing the box, or just add another layer over the entire height X width of the front and cut out the port opening
make sense?
TeamGG
Team D.O.A.
Old 08-02-2010, 04:01 PM
Ego Crusher
0/11 sssss1834
it makes sence the reason for the kerfed port was aesthetic I really like the way they look .
Ego Crusher
0/11 sssss1834
also if the box design is wrong could someone tell me what i would need to do to fix it
Old 08-02-2010, 04:02 PM
Decaf's Avatar
0/11 sssss3460
me too, lol
im no good with kerfs, they always snap when i try to curve them
TeamGG
Team D.O.A.
Old 08-02-2010, 09:52 PM
Ego Crusher
0/11 sssss1834
can anyone else help with the kerf
