Help with port 15" AQ hdc3 alum in 3 cube box - Car Audio Classifieds!
Old 08-04-2010, 02:15 AM
djseven's Avatar
0/11 ssssss111
Default Help with port 15" AQ hdc3 alum in 3 cube box
Ok, I have a 15" AQ hdc3 alum in a 3 cube box and hitting very loud!
145.5 at the dash on a term pro with a AQ 3500.1 amp (new one)
Anyway, box is 3.14263 cubes before displacements because I do not know how to figure that out!
23Wx15.34Hx19.75L
I have a 6" Aero that goes back about 16 inches. I think that should be tuned at 35hz or so, but I cant hit low notes...its real punchy and peaks at 50HZ.
I want to lower my frequency for street and change the port when competing.
Any Ideas? Is there a way to bend the port with a curved pvc Like an elbow??
I dont think I can fit another 6" aero in the front..
Please any suggestions will help!
Please see box
Old 08-04-2010, 02:43 AM
0/11 ssss31247
remove the port, seal it off, fire it rearward, shut off the Subsonic Filter... and it'll kinda hit the low notes.
Old 08-04-2010, 10:51 AM
djseven's Avatar
0/11 ssssss111
Subsonic filter!! I never really looked into what that even does..
I assume that it would cut out any unwanted (hamrful frequencies)
Old 08-04-2010, 10:52 AM
djseven's Avatar
0/11 ssssss111
Is it possible to do a port in and port out together or would they just cancel each other out??
bigjoker's Avatar
0/11 sssss2467
pm tommyk
Old 08-04-2010, 10:56 AM
djseven's Avatar
0/11 ssssss111
tommyk90 ??
bigjoker's Avatar
0/11 sssss2467
Originally Posted by djseven View Post
tommyk90 ??
yup
Old 08-04-2010, 04:19 PM
0/11 sssss1943
adding another 6" aero port would just raise the tuning even more. The size of your box is probably your main problem.
DC LVL 4 XL Vs. AQ HDC3 Alum Coils. Josh Wahlie General Car Audio Discussion & Questions 36 06-27-2010 06:13 PM
[SOLD]15" 3hp NEO dual 2 ohm with Carbon Fiber cone and Alum Dustcap jdubbau 15" Subwoofers 10 12-30-2009 04:13 AM
[FOUND] 2 6" Spun Alum Concave Dustcap tc3k101 Wanting to Buy (WTB) 16 12-01-2009 02:31 PM
Sub touching Alum aero port... snb778 Enclosure Discussion & Design Construction Help 19 11-03-2009 10:04 PM
aq hdc3 10 sub box 1.44 @ 38hz L Port GearGuy2001 Build Logs 4 04-25-2009 01:36 PM
