8 SA-10's box - Car Audio Classifieds!
Old 08-05-2010, 03:41 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Default 8 SA-10's box
Mainly lows, most likely aero'd, demo/daily groundpounder, powered by an AQ3500d.1 most likely at half ohm...suggestions on size, amount of what size aero's and tuning. Would like NO higher than 32hz if I can pull it off. A design would be sweet as sh*t too lol
Old 08-05-2010, 03:42 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Would like to keep it within these dims...46w-22h-25d. I can go 28d but that involves port up
Old 08-05-2010, 03:59 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
The dims give me the right airspace but the port is the tricky part. Subs up port back obviously
Old 08-05-2010, 04:24 PM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Anyone got any ideas? I know you're on Jacob lol.
Old 08-05-2010, 05:10 PM
0/11 ssssss714
I don't have time right now but I can draw something up for you on google sketchup when I get a minute....possibly later tonight.
Old 08-05-2010, 05:42 PM
MisterGrubbs's Avatar
0/11 sssss2358
Don't hold me credible because I'm not much of a box designer, but
According to my calculations, with a double baffled top using 3/4" wood and 8 SA-10's...
After woofer displacement you'll have right at about 11^ft(This is assuming net airspace before sub and port is 11.95 and 8 of the SA-10's displace about .96 best I can figure...)
If I'm right, using 4 4" Ports at 12" of length each will give you 29hz and leave you with around 10.6^ft for the woofers to share(without including the bracing you'll be using).
Now, that's not much port in regards to sq in, and I'm not a box designer(let someone else on here do a real design)
But it should definitely be do-able, just giving you preliminary insight
Once again, I'm not a designer so don't hold me credible
Old 08-05-2010, 05:48 PM
0/11 ssssss714
I threw something together really quick:
Should come out to [email protected] after port/sub displacements. Needs some internal bracing still. Port is 19.75'' x 6'' and 30'' long. I left out the double baffle but once that's added in the box will be 46''w x 26''d x 22''t.
Old 08-05-2010, 05:52 PM
0/11 sssss2358
Kharps, that wont work. It's going in a Trailblazer I think and you're not leaving enough room for all 8 subs to be firing upward with that port...although once again I could be wrong.
Old 08-05-2010, 07:13 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
http://www.youtube.com/watch?v=hQMzkDU8vOs
6 up, 2 forward, 2 6" ports back....tuned at 32hz....retardedddd lows and hardly any power
Youtube VIDz :
Old 08-05-2010, 07:31 PM
0/11 sssss2358
^^^Proven box design, why not right?
WTB solox 10's, ddz series, High end SPL 10's db daddy Wanting to Buy (WTB) 6 03-12-2010 07:59 PM
4-8's or 2-10's moneruff1982 General Car Audio Discussion & Questions 1 03-12-2010 06:05 PM
which 10's? obrien202 General Car Audio Discussion & Questions 21 08-22-2009 07:08 AM
EVO 10's I just got in :) RE_XXX General Car Audio Discussion & Questions 40 06-15-2009 10:51 AM
