4 18" sundowns , s10 clamshell ported help - Car Audio Classifieds!
Old 08-08-2010, 11:24 AM
0/11 ssssss222
Default 4 18" sundowns , s10 clamshell ported help
built a few walls and many of boxes but nothing like this . im trying to stuff these 4 18's in my truck . with my walkthru the opening into the cab is 42 at the top , 50 at the bottom . my problem is i dont have the first idea on how to tune a box this big and exactly how it should be ported .
Old 08-08-2010, 11:38 AM
0/11 ssss31247
I'd like to see it have slot ports at the base of the >.
It would have similar properties to other enclosure designs. {tapped horn}
I think it'd kick some major ass.
Old 08-08-2010, 11:42 AM
0/11 sssss3986
lol do a 4th order if you got the room. do a sealed clamshell at the rear and port the front.
like 2.5 cube per sub sealed. so 10 cubes sealed and like 40 cube ported. if you have a walk through im sure u have 50 cubes to work with. if not 40 cubes port 30 would be fine too.
Old 08-08-2010, 11:45 AM
0/11 ssssss222
im sure i have the room too lol , how do i go about tuning the port on a 4th order ?
Old 08-08-2010, 11:47 AM
0/11 sssss3986
Tune the ported chamber like a ported box.
Old 08-09-2010, 01:34 PM
0/11 ssssss222
ok that doesnt sound to be to hateful . what kind of response can i expect from this style of box . ive tuned some boxes in my truck pretty low but they seem to fall flat for the lows . for some reason my truck doesnt respond well to them .
Old 08-09-2010, 01:42 PM
0/11 ssss31247
The response you get is determined by the airspace you have.
If you give a 4th order the correct amount of rear airspace, the size of the front chamber and it's porting will determine if the sound will be smooth like a sealed enclosure or peaky like and SPL designed ported box.
Sundowns running at under 12vs? Erikls9210 (Sundown Audio) 12 06-03-2010 01:34 PM
box for ported 12" PSI P1 Mac2118 Enclosure Discussion & Design Construction Help 2 04-16-2010 09:28 PM
[SOLD] 15" ported enclosure 4" aero ports gbo559 Wiring, Electrical & Other Installation Equipment 3 01-05-2010 01:01 AM
Clamshell? SCHMITTY Enclosure Discussion & Design Construction Help 7 10-14-2009 02:49 AM
clamshell questions kurrupt General Car Audio Discussion & Questions 118 06-30-2009 01:13 PM
