Fi audio 15" Q 4th order help - Car Audio Classifieds!
Old 08-10-2010, 10:33 PM
0/11 ssssss400
Default Fi audio 15" Q 4th order help
I'm building a 4th order for a 15" Fi Q. I'm modeling it WinISD but its going weird on the power handling chart, and impedance.
But anyway I've got two models (rear chamber is sealed, front is ported)
#1 2.5 sealed with .8 ported @ 46.2hz. Models flat from 35-63 and f3 is 25hz. Very flat response.
#2 2.75 sealed 1.0 ported @ 45hz. Flat from 39-52 F3=27hz. Has 1.3dB more gain (at peak) than option 1.
Does this seem right for a 15" in a 4th order?
I've never built one before so I'm asking for help.
Also what size port should I use (I know ported is the 10-16 ratio)?
Is a 4" port too small?
Old 08-11-2010, 09:33 AM
0/11 ssssss400
I've never built a bandpass but those volumes seem to small.
anyone?
Old 08-11-2010, 09:34 AM
0/11 ssssss400
anyone?
**WTT: 4th Order Bandpass for 3 10s"** 528hz Car Audio Trader (WTT) 12 08-09-2010 05:24 PM
4 18" 4th order... Scapelli21 General Car Audio Discussion & Questions 25 07-02-2010 05:32 PM
**FS: 4th Order Bandpass for 3 10s"** 528hz Wiring, Electrical & Other Installation Equipment 5 04-25-2010 08:38 PM
10" 4th order grimreper912003 Enclosure Discussion & Design Construction Help 12 01-28-2010 10:40 AM
2 10"s 4th Order rmzsuzuki89 Build Logs 36 12-06-2009 08:56 PM
