4th order help - Car Audio Classifieds!
Old 08-11-2010, 01:25 PM
Brand New Members
0/11 ssssssss3
Default 4th order help
trying to design a 4th order bandpass for two 15" kove armaggedon U2 subs. each sub will have 2000 watts each. never made one before any help apreciated thanks.
Old 08-11-2010, 01:45 PM
0/11 ssss31247
{not including displacements}
6 cu ft front
6 cu ft rear
50hz tuning
(2) 8" ports 12" long
OR
(4) 4" ports 6" long
Old 08-11-2010, 02:24 PM
Brand New Members
0/11 ssssssss3
Thank you, what if i wanted to tune lower?
Old 08-11-2010, 02:44 PM
TEAMLOWPOUNDERS
0/11 sssss3564
i thought your suspose to make the front 2x the size of the rear??
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 08-11-2010, 02:58 PM
0/11 ssss31247
Tuning lower will reduce your SPL and overall response drastically. {read: it will make your 15s be quieter than 10s..but move more air.}
4th order tuning needs to be centered on the frequencies you wish to reproduce.
Originally Posted by SUBW123 View Post
i thought your supposed to make the front 2x the size of the rear??
You can but that is neither a requirement nor a cure-all.
Some speakers do need a much smaller rear chamber and some speakers are not suited for bandpass but it's really determined by the specifications.
The recommendation I made gives the widest bandwidth possible and the most SPL possible. {very musical and very loud}
I did generalize it a bit to make it easy. Enclosures don't need to be impossibly hard to build.
Old 08-11-2010, 03:04 PM
0/11 sssss3986
I dont know where you get your theories on how a bandpass works but i would never design one smaller than a 2 to 1 ratio. if anything i would do around 2 cube per 15 sealed and like 10-12 cubes ported tuned in the mid 30s. and thats for a daily setup.
Old 08-11-2010, 03:14 PM
FLAstrongman's Avatar
0/11 sssss1156
Feedback Score: 21 reviews
tuned in the mid 30's huh? Have you ever actually heard a 4th order tuned below 40hz? It's not very impressive, nor does it play any type of real music. The only thing you can listen to is slowed down songs. When you are tuning a bandpass you are tuning the front chamber to the cutoff frequency. That means it has a drastic roll off after tuning.
Old 08-11-2010, 03:25 PM
jbizzle's Avatar
0/11 sssss4346
Feedback Score: 26 reviews
Yes, HIS OWN CAR. Its tuned to 30hz and has a very flat response.
'07 Chevy Trailblazer SS AWD (Garage Queen)
- Alpine 9887
- Eclipse SC8365 3-Way front stage
- Sundown SAX-125.2
'98 Jeep Grand Cherokee (Daily)
- Alpine 9887 (Active)
- Selenium 6" Mids, 4 Crescendo CTS-1 Tweeters
- Sundown SAX-100.4D
- 2 Sundown SA-12s
- Sundown SAZ-1500Dv2
Team Sundown Audio
Old 08-11-2010, 03:28 PM
0/11 sssss3986
is that why i do over a 150 from 22hz to 58hz peaking at 30hz. which my ported chamber is tuned to 30hz.
Wanna-B-Basshead's Avatar
0/11 ssssss355
mines 6 sealed: about 24ish ported for 3-15"s. peaks at 51hz, doesnt really like <30 hz
Travis Atherton
Team Big Guys!
2005 World Finals Street C
2005 CHEVY SILVERADO 3500 CC/LB/6" lift
3 American Bass XFL 15"s 1 HIFONICS GOLIATH
Want to try a 4th order Boyd Heaton (DC) 5 03-01-2010 08:54 AM
4th Order Help. SpeakerBox General Car Audio Discussion & Questions 4 02-08-2010 03:41 PM
anybody done a 4th order in an suv? toolmaker Enclosure Discussion & Design Construction Help 2 12-14-2009 09:32 PM
4th order help mcbuggin Enclosure Discussion & Design Construction Help 0 10-25-2009 12:12 PM
