Smaller box equals higher rise? - Car Audio Classifieds!
Old 01-10-2009, 11:52 AM
Jbgabriel's Avatar
0/11 sssssss99
Default Smaller box equals higher rise?
Is that the way it goes? A bigger box has less rise so the sub sees more power? Thats what I have heard from someone over at termpro. Just wondering because I heard someone say different on here.
1999 f150
Current Setup:
Headunit: Premier 780-mp
Front: Powerbass SC-6
Front Amp: Boss 150wrms x 2
Substage:
Sub Amp: Autotek MM3000.1
Old 01-10-2009, 12:11 PM
Anotherguy's Avatar
Active Member
0/11 ssssss605
Yes that's right. Typically the larger the box the lower the impedence rise.
________
BUY SILVER SURFER VAPORIZER
Old 01-10-2009, 12:12 PM
DLP customs
Guest
0/0 sssssssss
on burps smaller box is louder. But music is a whole diffrent monster.
Old 01-10-2009, 12:50 PM
0/11 sssss6075
Bigger box is more efficient but also reduces power handling. So you're closer to the amps rated power but can't use as much of it..
Old 01-10-2009, 03:09 PM
Jbgabriel's Avatar
0/11 sssssss99
Wont the sub see the same amount of power either way though? With a bigger box you might have to turn the gain down with a given amp. But it would be seeing the same amount of power with that same amp running at a higher impedence in a smaller box. Am I missing something?
1999 f150
Current Setup:
Substage:
Old 01-10-2009, 03:36 PM
the bigger the box the more air it has to compress and the less resistance the cone has to fight against to move
the less resistance it has the easier to bottom out and smack the coil to the back plate (not including impendence rise) the only thing the box size does to the sub is allow it to move and be more efficient
and the reason small boxes are used for burps is the control of the woofer and they are very peaky which is good for spl use
smaller pulley at idle? splvictim20 General Car Audio Discussion & Questions 43 01-05-2009 07:00 AM
[FOUND]WTB: Some smaller thing's for the rebuild splvictim20 Wanting to Buy (WTB) 23 11-10-2008 11:19 AM
