deciding on a box...help? - Car Audio Classifieds!
Old 08-13-2010, 01:43 AM
0/11 sssss8594
Feedback Score: 55 reviews
Default deciding on a box...help?
so ive been using the re box calculator to come up with my box design and so far ive come up with 3...which would be best for daily use??...i no my designs so far have ALOT of port area but my designs are still in the works...i like big ports too...lol...but also, would i be better if i went with an aero port inside the box instead of a slot port??...box design is FAR from my thing so im doing my best rite now...also, how much should i account for with my sub displacement and bracing, each sub is .18cu??
1. 36"W x 11"H x 25"D
port width 6"
port length 5.5"
sq port area 57
3.342cu at 34hz
2. 36"W x 11.5"H x 23"D
port width 5.25"
port length 5"
sq port area 52.5
3.353cu at 33.942hz
3. 36"W x 11.5"H x 25"D
port width 6"
port length 5"
sq port area 60
3.536cu at 34.059hz
Enclosures
Old 08-13-2010, 01:45 AM
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
not trying to be a **** but every time i used res box calc something came out wrong and dman1 told me there software is off on frequencys.
WOW
Old 08-13-2010, 01:47 AM
0/11 sssss8594
ive herd that 2 but i dont have anything else to go by...i have NO CLUE how to use my winisd...i keep trying to learn but it nvr works..lol
Enclosures
Old 08-13-2010, 01:56 AM
mads10bass's Avatar
0/11 sssss7335
i just draw something up in google sketchup then calculate it all and use pspinc for my aero port needs and the12volt for my slot port needs.
WOW
Old 08-13-2010, 02:03 AM
0/11 sssss4714
www.ajdesigner.com is a good program that you could use, they have band pass, vented and sealed software to download!!
TEAM GORILLA
TEAM GHOST MOB
2007 Ford F150
1995 T-Bird P.I. 4.6L 312rwhp-Comp car,work car
Trunk Car class for 2011 MidwestSPL division!!
Old 08-13-2010, 02:05 AM
0/11 sssss8594
i was checkin out psp...for the volume tho, is that after displacement, bracing, port??
Enclosures
Old 08-13-2010, 02:10 AM
mads10bass's Avatar
0/11 sssss7335
you have to factor all that in. the 12 volt seems to be pretty accurate on size when you punch the #s in. then you subtract the displacement of the port/s subs and bracing.
WOW
Old 08-13-2010, 02:15 AM
0/11 sssss8594
man this blows...lol
Enclosures
Old 08-13-2010, 02:20 AM
0/11 sssss8594
i just realized re hasta be really off because on other box calc sites its showing that my box would be over 4cu before displacement but none of the numbers i got from re were over 3.5ish
Enclosures
Old 08-14-2010, 11:42 PM
0/11 sssss8594
who can verify that option 3 is correct in measurements??...i really wanna get my design ready so i can make the box
Enclosures
need help... deciding midnite toka General Car Audio Discussion & Questions 10 04-14-2010 07:13 PM
Need help again deciding what to do. themgators511 General Car Audio Discussion & Questions 9 02-08-2010 02:10 PM
Need help on deciding what to do... themgators511 General Car Audio Discussion & Questions 4 12-28-2009 08:54 PM
Need help deciding on what sub(s) to get SQL Monte General Car Audio Discussion & Questions 15 12-17-2009 09:15 PM
need help deciding fatpat1080 Enclosure Discussion & Design Construction Help 14 02-11-2009 12:20 AM
