port tuning? - Car Audio Classifieds!
Old 01-11-2009, 05:19 PM
98AckCL23's Avatar
0/11 sssss9929
Default port tuning?
i was reading a build thread on here the other day, and the port calculations really confused me. everything i've ever heard/read has been that in order to keep the same tuning frequency, when adding more port area, you have to lengthen the port. but what i read the other day was a port with a pretty large port area (~100 sq inches, i think) and a length of like 3". and the guy claimed it was tuned to like 32-35 Hz.
the box i'm planning on building i have like 20 inches^2 of port area, and a length of like 28". and it's tuned at just under 32 Hz.
can anyone clarify this for me/re-explain something that i might have missed?
Old 01-11-2009, 05:23 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
more port area means lower tuned....... i tune at 63 hertz... so its essentially not even a slot other than a hole in the box... lol
you probably wont like me
Old 01-11-2009, 05:25 PM
98AckCL23's Avatar
0/11 sssss9929
when i run a port length calculator on the12volt.com, it tells me that i need a longer port when i increase the port width...
Old 01-12-2009, 05:32 PM
98AckCL23's Avatar
0/11 sssss9929
anyone??
Old 01-13-2009, 12:56 AM
0/11 sssss1560
so run a longer port?
Old 01-13-2009, 01:00 AM
no more area means higher tuned if the length is the same
any way the length of the port is very different for every box size basically the longer the lower it is tuned but other things like flares and kerfs and bends throw the tuning off he may have been tuned that low if his box was big enough I have a design drawn up for my blazer that uses 6 15's and the port is only 2.25" long (the depth of the baffle) but is tuned to 30 hz
hope that helped
Rat style tuning snikwad General Automotive Chat 67 03-15-2009 05:23 PM
9.5 inch Aero Port Tinted Speaker Accessories & Parts 5 12-11-2008 10:39 PM
[COMPLEX] Determining the Tuning Freq. of a Vented Enclosure? danteBirosel Tutorials & Quick References 0 11-12-2008 01:49 PM
Need opinions on port. SPY Enclosure Discussion & Design Construction Help 6 10-04-2008 03:34 PM
How to: Figure port area SPL Guru Tutorials & Quick References 3 08-04-2008 10:24 AM
