Areo Port noise! - Car Audio Classifieds!
Old 08-15-2010, 04:44 AM
0/11 ssssss462
Default Areo Port noise!
So i built a box for my two 10" LA storms. The box size after displacement is 2.5 and suppose to be tuned to 32 hz. I have two 3x12" in length areo ports with exiting flare on it but not the entering flare on it for inside the box (no room). Now on some notes i get alot of port noise, does this mean i need more port area?
thanks
Old 08-15-2010, 05:47 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
I'd say you were a little short on port area. Especially without the other flare. You can get away with less port by using aeros because they are more efficient, but you are killing that efficiency by not utilizing both flares. Can you port externally so that you can fit the flares in there?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 08-15-2010, 12:39 PM
0/11 ssssss462
Reason i don't have end fare on is it wont fit on the inside of the box, my box is for under my rear seat. It starts to tapper down in the back. i could possible to to add 90's but idk how that would work.
Old 08-15-2010, 12:50 PM
0/11 ssssss400
Do you have 3" from the rear of the.box to the rear of the port? That could affect it. And your low on port area.
Your getting more turbulence near Fb (box tuning)?
Your box looks very nice though, what subs are you using?
Old 08-15-2010, 01:08 PM
0/11 sssss6981
Why not buy corner knuckles and extend the port sideways which will allow to add the end flare
Old 08-15-2010, 01:13 PM
0/11 ssssss714
I've used 90s on 3'' aeroports before. Go up to home depot or whatever store you have near you and buy some 3'' pvc 90s and some abs glue. It comes with a brush, apply it to the outside of the aero tube and the inside of the 90 and let it set. You'll be good to go. The 90 is probably $3 buck a pop, abs glue might be around $5.
Old 08-15-2010, 01:18 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Just pull the ports out of the box unitl you have enough room to fit the flares. Or do you not want to go external at all?
4x world champ
- Floyd E. Toole
Old 08-15-2010, 03:32 PM
0/11 ssssss462
yes the port ends are about 4"s awaya from back wall.
Subs are 10" 3hp customs..
Old 08-15-2010, 03:34 PM
0/11 ssssss462
yes the port ends are about 4"s away a from back wall.
Old 08-15-2010, 03:51 PM
Man Behind the Curtain
0/11 sssss1699
Your getting noise cause of the sharp edge of the port tube. You can make a small flare to help or bend the tube till you can fit the full flare on the inside.
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 08:59 PM
port noise ellocojorge General Car Audio Discussion & Questions 26 05-24-2010 04:45 PM
Mesh Over Port = Port Noise????? or Not crownvic02 General Car Audio Discussion & Questions 13 03-18-2010 04:25 PM
eliminating port noise F3M4 General Car Audio Discussion & Questions 3 07-14-2009 12:26 AM
67.5in^3 = port noise? RollerDJ Enclosure Discussion & Design Construction Help 5 05-26-2009 12:55 AM
