Subs up----port to the side - Car Audio Classifieds!
Old 08-15-2010, 09:18 AM
0/11 ssssss714
Default Subs up----port to the side
Anyone ever done this in a suv for daily?
Old 08-15-2010, 09:32 AM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
small spl boxes ive seen some, u dont have as much rear hatch flex when u arent loading it, im guessing thats why the scores were a little higher firing to the drivers side rear
TeamGG
Team D.O.A.
Old 08-15-2010, 09:57 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
In a 4runner it was nearly 2db quieter but I had my daily 38hz single 15" box turned sideways like that for a while, a little less rattling was nice though lol
Old 08-15-2010, 10:37 AM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
Yes.
Old 08-15-2010, 10:39 AM
0/11 ssssss530
i have that now it seems louder port driverside but i cant definitely tell cause i have no term lab
98 ford explorer
HU: power acoustik ptid-8001n
mids and highs: RE FR 6x8's
Sub Amp: pheonix gold v752
Sub: e8
free bass tests
Old 08-15-2010, 10:52 AM
0/11 ssssss714
I'm trying to keep the box 20'' deep or less, which is creating some problems when trying to come up with a design to fit rear firing aeros. I'd have plenty of room if I could fire them to the side though.
Old 08-15-2010, 11:30 AM
0/11 ssssss798
i have mine ported to the pass side.... seems to be better than facing the back. Also allows for a longer port (esp. with aero's) since the width is greater than the depth available
Getlikeme:remote start
REFS: (from CA.com)Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle, mlstrass , Mazzasec, SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic meade forum. Team_Psi reconed SSX, Timmy13091 sold Deka Battery,
Old 08-15-2010, 12:15 PM
R_Mac_1's Avatar
0/11 ssssss589
Mine is like that, but it's a 12" Alpine Type E on 300 watts...nothing special. It honestly is pretty loud for such a cheap/low power sub.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB head unit
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35hz)
Sundown SAX-1200D
Old 08-15-2010, 12:18 PM
0/11 ssssss714
That's exactly the problem I'm having, not enough depth to the box. If I do 3-12s or 4-10s I'll have to do side firing aero. If I do 2-15s I might be able to get away with rear firing slot, possibly even aeros but I'd be cutting it close on port area.
Old 08-15-2010, 12:43 PM
0/11 ssssss798
problem with doing it in front or back in an SUV is you usually have to have an L in the slot port, which takes up much more space, so obviously the box will have to be significantly bigger... which is another reason I went Aero.. I just like them better.. leaves the option to change tuning.. I've even cut the port baffle off and changed port configs
should I wall or inverted subs up port back for 2 18's...?? NorthBeat General Car Audio Discussion & Questions 5 07-29-2011 10:07 PM
subs up/port back in a trunk car? Fatboy501 General Car Audio Discussion & Questions 71 06-15-2010 04:42 PM
Subs Up, Port Back In a Trunk? 350zkid General Car Audio Discussion & Questions 14 08-25-2009 04:34 PM
Subs on font and side bassman_soundking General Car Audio Discussion & Questions 3 03-17-2009 07:58 PM
