input please Solo X - Car Audio Classifieds!
Old 08-21-2010, 12:48 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
Question input please Solo X
OK here is the situation
Stetsom 2k5 2ohm
One Kicker Solo X 12" dual 1
max box size 16t X 18d X 32w
The car peaks at 42hz and is a trunk
I know the solo x like bigger boxes, but in a 3 cu box it will only like to see 1500w or so and the imp rise is pretty stiff. I was looking at going down to a ~2cuft box with 2-4" areoports going through the deck into the car and firing the sub to the rear of the trunk. I am looking for some confimation that I am going in the right direction with this as the way I see it, the imp rise is less with the smaller box, the power handling is better with the smaller, and 2-4inch ports are pretty close to acceptable. I am looking to play to the mid-high 30's and have the imp rise close to that also droping to 2 ohms by the low 40's and the second rise 70 or above. I know I am not asking for much.
I have modeled a few boxes but they typically show some pretty ugly rise or tuning is higher, or the rms is 1500 or so
Any thoughts would be greatly appreciated
thanks
Old 08-21-2010, 01:41 AM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
Your X will want twice that much power if you cut that box down to that size. I'm putting 1500w per X 12 and each of them have 5.85 cu. ft. after displacement
Edit: Keep in mind that while you can cut down on impedance rise with a smaller box, you also cut down on efficiency. I can attest to the fact that X's love big boxes and you can always try Kicker tech although there's a good chance you'll get as much help as I did: "Uh that sounds good"
Stupid Loud.
Old 08-21-2010, 02:13 AM
0/11 ssssss408
i'd shoot for one 6'' aero if you can do it, instead of 2 4'' aero's
Old 08-21-2010, 02:14 AM
0/11 ssssss408
and x2 on what wickedwitt said, i haven't owned any solo x's but have heard over and over they like big boxes
Old 08-21-2010, 02:16 AM
0/11 ssssss408
Stetsom 2k5 2ohm
thanks
i would think about sealing off the trunk and doing sub forward port forward
Old 08-21-2010, 10:18 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
so do you think it will take 2500w daily in a 3' box?
Please help with amp input!!! dadydolas General Car Audio Discussion & Questions 7 08-16-2010 12:12 PM
need input. Highs On Bass Enclosure Discussion & Design Construction Help 27 06-10-2010 11:10 AM
need input kingmade08 General Car Audio Discussion & Questions 16 04-11-2010 10:44 AM
Ok, i need some input plz amcreynolds3 General Car Audio Discussion & Questions 5 08-01-2009 01:32 AM
