new box for 2 hdc3 12's? - Car Audio Classifieds!
Old 08-25-2010, 02:56 AM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
Default new box for 2 hdc3 12's?
I currently runnin 3500d on 2 hdc3 12 copper d1's in box designed by chris at fishercustoms.com. It sounds good on any music, but doesnt pick up the lows that much. The box I have now is subs up, center port firing back tuned to 36 hz. I believe he said its 4.25 cubes net with like 65 square inches of port. I have up to 49" wide x 36"D x 18"H. Any suggestions on tuning lower or building box smaller? Pm me if you can do design and how much
2 FI bl 18's walled in 2012 scion xb
Old 08-25-2010, 08:46 PM
0/11 sssss1943
How far away is the port from the rear hatch?
Old 08-25-2010, 08:59 PM
0/11 sssss5305
check your SSF first as that box should drop plenty low...
Old 08-25-2010, 11:42 PM
98Expo's Avatar
0/11 sssss1929
Box is 8-10 inches from rear hatch, will check tunin when I get home from work
Old 08-25-2010, 11:58 PM
0/11 sssss5305
placement sounds fine. Could try moving it closer to the hatch and see if that changes things..
Old 08-26-2010, 02:27 AM
98Expo's Avatar
0/11 sssss1929
thanks, i was going to rebuild a little smaller and increase port area like you said before. I just got home from work, so will check everything tomorrow before work
Old 08-27-2010, 04:30 AM
98Expo's Avatar
0/11 sssss1929
thanks mlstrass, ssf was a little high, I changed that, and seems to have helped a good bit. I am running these until they sale so really dont want to bother with new box now.
2 hdc3 12's or 4 sa-12's 98Expo General Car Audio Discussion & Questions 15 09-15-2010 08:04 AM
2 hdc3 12's box help dylan9999 General Car Audio Discussion & Questions 9 08-12-2010 12:59 AM
Need an AQ HDC3 motor (or blown hdc3) Bsktbll895 Wanting to Buy (WTB) 0 06-16-2010 08:39 PM
3 aq hdc3 12's blkmrideon22s General Car Audio Discussion & Questions 2 05-17-2010 04:50 PM
2 12's v 1 18 hdc3 who's louder ? donkryder954 General Car Audio Discussion & Questions 20 11-27-2009 02:58 AM
