4th order box help - Car Audio Classifieds!
Old 08-26-2010, 10:11 AM
0/11 ssssss222
Default 4th order box help
thinking of getting 16 12's for my s10 and want to do a 4th order box but im not sure on how much air space per 8 subs and then how much air space in the open chamber . port i can figure out though lol
Old 08-26-2010, 10:28 AM
0/11 sssss1230
Do 6-8 cf per 8 and 30-40 total on the ported side.
If your limited on space do 4cf per 8 and 16cf on the ported side.
Team Excessive
Old 08-26-2010, 10:29 AM
0/11 ssssss222
and with the port do i tune it like a normal ported box ?
Old 08-26-2010, 10:32 AM
0/11 ssss31247
Default here is a lazy way to do this;
Make the rear chamber the manufacturer recommended size for a sealed box.
Make the front chamber the manufacturer recommended size for a ported box. {then tune it to 60hz}
ASSUMING the Manufacturer rec;
1 cu ft sealed
1.5 cu ft ported
your total would be 2.5 each. 40cu ft for 16
will it work?
hell yes it will.
Old 08-26-2010, 10:59 AM
0/11 sssss1230
Not really. I like mine around 50-58 hz depending on vehicle. But you might like it a little more low end dependant.
Team Excessive
Old 08-26-2010, 11:01 AM
MisterGrubbs's Avatar
0/11 sssss2358
I dont want to make myself seem important by jumping in with those two, but you want to tune 50hz or above on a bandpass, like sonic and AudioXtremes have both stated. It will still play much much lower than 50hz, just have to have faith in that one
Old 08-26-2010, 11:12 AM
0/11 ssssss222
well all this has been very helpful but i measured the bed out and i dont have 60 cubic feet to work with . my other option is the 4 15's the stereo shop offered me @ their cost just to try them out .
Old 08-26-2010, 11:18 AM
0/11 sssss2358
That answer is actually simple.
I did a little bit of research not too long ago on a S-10 Single cab, 97 model.
With allowing room for a battery bank/amplifiers, I had enough room for 12 12's in a 4th order
Consider that? And with that, you could buy better woofers
4th order ramos7 Enclosure Discussion & Design Construction Help 1 07-26-2010 07:00 AM
2 4th Order 10s D4 GearGuy2001 Wanting to Buy (WTB) 10 07-05-2010 09:31 AM
4th order help mcbuggin Enclosure Discussion & Design Construction Help 0 10-25-2009 12:12 PM
In order fatpat1080 Uncensored Off Topic 26 07-01-2009 11:17 AM
