My design for 2 18's, why are the port calcs so different?? - Car Audio Classifieds!
Old 08-29-2010, 11:46 PM
0/11 ssssss442
Default My design for 2 18's, why are the port calcs so different??
Im looking to build a box for my 2 18's. Subs up port back slotted across the bottom.
INTERNALLY my box design is 22.125" height, 36.5" width, 35" depth.
Which gives me 16.357 cubes.
My port is designed to be 6" tall and 36.5" wide inside and 26" deep, which displaces 3.63 cubes. (using box bottom and sides as 3 of the port walls)
So im left with 12.72, my subs wont displace anything as they will be invert mounted, then after some dowel bracing Im estimating Ill be at almost bang on 12 cubes net for the pair
Now what Im a little stuck on is if I punch those number in 12volt.com and carstereo.coms calculator I get much different numbers. Im loolking for 36hz and I think my port @ 26" deep gives me that.
Carstereo.coms calculator seems off though, if you punch my numbers in and select the "slot port yes" option it says to make my port 6" long, but if you only change it to slot port no, it goes to 24"... but my box technically is a slot port so I dont know what to think here
Anyone have any opinions??
I plan to make a port plug to turn the port into something like 24" X 6" which would turn it to high twenties tune.
Im thinking of building this tomorrow if I can get some confirmation on my numbers!!
Thanks!!!
Old 08-30-2010, 12:01 AM
Dbmonster's Avatar
0/11 sssss1217
my box calc is coming up with a 34hz tune for your design.
what subs and amps are you using? because that port is kinda big, almost 18sqin of port per cuft. if your running alot of power you may wanna shrink the port down a little.
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 08-30-2010, 12:03 AM
0/11 ssssss442
They are going to be HDC3 18's with PSI alum recones. Havent decided on power yet but most likely 2 AP 3ks
Just a daily driver will never see a meter, just need to play music reliably
Old 08-30-2010, 12:05 AM
0/11 ssssss442
the port is a little on the big side for the higher tune, which is what I may end up using, as I think the Aq's even though they are being reconed may still like the high tune, but Ill also make a port plug to tune it to high twenties just for shits n giggles.
Whatever one sounds better, I'll keep it that way
Old 08-30-2010, 12:18 AM
Dbmonster's Avatar
0/11 sssss1217
I was thinking you might be using AQ's given the port size. if i were you i would keep the same port size, but cut it down to 18" long. this will bring your tuning up to 36hz and will increase your net volume to 13.44cuft giving you 16.29sqin of port per cuft. since your not going after numbers i wouldnt go too big on the port area with the amount of power you will be running.
Old 08-30-2010, 02:13 PM
0/11 ssssss442
That sounds like it could work
Old 08-30-2010, 02:15 PM
bobbygilly's Avatar
Owner of UE
0/11 sssss6562
Feedback Score: 23 reviews
check your box with pen and paper....calculators tend to be off
Team Unlimited Excursion
get low or die trying....
Old 08-30-2010, 02:24 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
the dowel will likely not take up more than .4cuft
i would do 5.75" height X 36.5" width X 21.5 deep
[email protected] w/210sqin... 16.5sqin/cuft.... should be great daily
TeamGG
Team D.O.A.
Old 08-30-2010, 02:42 PM
Decaf's Avatar
0/11 sssss3460
if you want to utilize a port plug u could make the plug 10" X 5.75" (152sqin remaining) and it would drop tuning to 30.5hz if u want to really slam lows or demo more air movement
TeamGG
Team D.O.A.
Old 08-31-2010, 02:55 PM
0/11 ssssss442
Im loving this port plug idea
should I wall or inverted subs up port back for 2 18's...?? NorthBeat General Car Audio Discussion & Questions 5 07-29-2011 11:07 PM
Help on port design? SUBW123 General Car Audio Discussion & Questions 15 08-23-2010 06:04 PM
need help on port for box design for sa-10s. akmarcos12gauge (Sundown Audio) 2 08-06-2010 01:58 PM
cubes and port sizing for 18's Violence* Enclosure Discussion & Design Construction Help 6 11-04-2009 05:45 PM
BOX DESIGN NEEDED ASAOP x2 DC LVL 5 18's! jdubbau Enclosure Discussion & Design Construction Help 0 07-28-2009 09:44 AM
