Correct port tunning. 12volt? bbp6? - Car Audio Classifieds!
Old 08-31-2010, 03:10 PM
Brianyakno's Avatar
0/11 ssssss726
Default Correct port tunning. 12volt? bbp6?
I'm building a box this weekend for a rd audio alpha 12" hybrid. i have been told that 12volts tunning calculator is off. i have been using it for all my other boxes. seems the same as re's calc. Is bbp6 program on point for building a good enclosure. I am trying to get my tunning down because i want to build a permanent box and stick to single 12" woofers. seems like bbp6 says you need a longer port to reach the same tunning(box calc is higher tuned than it says). according to 12volt my slot ported box was 30hz seemed dead on with a aa ava driver, and my current box aero port is tuned to 26hz absolutely kills the lows high end is not so good after about 60hz the brutality wears off. Anybody hear using bbp6 or have anything to say 12volt isnt dead on?
-BriAn
Sundown x 10" Audiopipe 15001d Audiopipe 0 gauge wiring kit Stinger spv70 1.4 cuft slot ported box to 28hz
Old 08-31-2010, 03:14 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
use this, u'll never use anything else again after trying it, ur inputs go in the equation at the bottom so you know 100% it is accurate
Torres' Box Calculator
unless you want to plot it too for response, but thats just a theoretical graph that rarely is correct
TeamGG
Team D.O.A.
Old 08-31-2010, 03:38 PM
Brianyakno's Avatar
0/11 ssssss726
ill try that out when i get home later thanx man
-BriAn
this would be 6th order correct? jj53913 Enclosure Discussion & Design Construction Help 25 05-25-2010 11:07 PM
tunning sheldonfromltown General Car Audio Discussion & Questions 7 02-16-2010 03:31 PM
BBP6 download, but got problems toolmaker Off Topic Chat 3 07-05-2009 10:26 PM
Need an amp, need your help to find a correct one. Bologna General Car Audio Discussion & Questions 3 04-27-2009 09:52 PM
enclosure tunning? newarkbeast973 General Car Audio Discussion & Questions 12 04-07-2009 10:13 AM
