Port Tunning - Car Audio Classifieds!
Old 09-05-2010, 12:29 AM
0/11 sssssss13
Default Port Tunning
I have an audiobahn 15" subwoofer...the manual recommends to tune the port to 35hz...what would happen if I do less than 35? and what would happen if I tune it higher than 35? How would the sound be affected by the different hz??
If you have a site that I can visit to get informed, please post it...
thanks to all who reply...
Old 09-05-2010, 12:35 AM
Super Moderators
0/11 sssss9623
its prob gonna suck no matter what imho
Old 09-05-2010, 01:33 AM
0/11 sssssss13
XJoey...
the question was not about the sub, it was about the port...thanks for your reply but it still doesn't answer my question...
Old 09-05-2010, 01:36 AM
MR_MT's Avatar
Active Member
0/11 ssssss741
tuning lower (should) give an overall lower sound to the sub. tuning higher will... yup you guessed it! Tuning at 35hz is round about middle of the road. I would tune no lower than 28hz and no higher than 42hz
Nothing special
Old 09-05-2010, 02:01 AM
528hz's Avatar
0/11 sssss1792
Typically, the enclosure size is a big factor as well. Coensiding with the tuning frequency, the enclosure will determine, for the most part, how the sub is going to perform.
I would ask youself, " Do I want this sub to sound boomy or punchy." Take into consideration what you'll listen to most of the time. "Usually" the bigger the box, the boomier the sound. Of course the higher the tune, can also produce a more boomy sound at mostly higher frequencies at or above tuning.
Lots of factors can play a role...what is the Fs of the sub?
Old 09-05-2010, 02:08 AM
mytyeerinpie's Avatar
Elite Master Member
0/11 sssss6375
Whats "Tunning?" looks like 528hz has you covered though
Posted to Monty
as it is you would have been better off with a 50cc hot pink moped with slutty on the plate
im sry bro but actions like this bring down you and the whole site....this is a place to help and or learn car audio along with selling used car audio equipment.....posting to get a rise out of ppl is not only childish it hurts caco on the whole.....
Old 09-05-2010, 02:15 AM
omgitscollin's Avatar
0/11 ssssss984
were about to learn
just sign this line and ill make all your wildest dreams come true sir
Correct port tunning. 12volt? bbp6? Brianyakno Enclosure Discussion & Design Construction Help 2 08-31-2010 03:38 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
tunning sheldonfromltown General Car Audio Discussion & Questions 7 02-16-2010 03:31 PM
enclosure tunning? newarkbeast973 General Car Audio Discussion & Questions 12 04-07-2009 10:13 AM
