box input please! - Car Audio Classifieds!
Old 09-06-2010, 09:32 PM
jimmay's Avatar
0/11 ssssss481
Default box input please!
Alright after hitting a 140.8 im looking to try and improve with a new box. Currently i have my box firing towards the back of my trunk. It should be about 2.2 or so cubic feet. I was thinking about firing my sub and port into the cabin and sealing it off from the trunk. I know this topic is debatable and ive google the topic on whether its louder or what.
I was hoping I could get some input on this. I can go 15 high 32 wide and however deep i want. I was thinking about tuning it to about 38 hertz. My rear seats do not fold down, but i can take them out in about 5 or so minutes for comps. Do you think i can gain by firing my sub forward?
Equipment
1 HDC312 copper
1 Aq 2200d
HU: Alpine 9887(Active)
Front Amp: Sundown 50.4
Rear Amp: Profile Baja HA1000
Sub Amp: AQ 3500
Subs:
Front Stage: Tweeters: Vifa Dome tweeters Mids: Dayton Audio Reference 7 inch woofers
Batteries: Xs D2700, D975, Orbital Purple Haze
Team DOA
Old 09-06-2010, 09:34 PM
TEAMLOWPOUNDERS
0/11 sssss3564
[robably will drop db's if you fire front and dont seal it off...is it the new style aq?
you could also try using aeros tuned higher mabey 38 39hz
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 09-06-2010, 09:36 PM
jimmay's Avatar
0/11 ssssss481
I was going to seal it completely and its the new version.
Sub Amp: AQ 3500
Subs:
Team DOA
Old 09-06-2010, 09:39 PM
TEAMLOWPOUNDERS
0/11 sssss3564
if it was me i would make new box with aero ports seal it of firing into cabin mabey 2.0 cubes tuned to 38hz....thats iof your just going for spl...and idk what you have the gains set at but my buddys new copper coil takes 3k with ease
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
Old 09-06-2010, 09:45 PM
jimmay's Avatar
0/11 ssssss481
Ive thought about the aero port idea....it would probably be better for tuning purposes as i could just swap ports. I am going for spl...but i do listen but i do alot of driving now so i listen to alot of music. I do think my setup sounds pretty good though with music.
Sub Amp: AQ 3500
Subs:
Team DOA
Old 09-06-2010, 09:48 PM
TEAMLOWPOUNDERS
0/11 sssss3564
well i wouls say tune to 38hz you say you would have more spl than daily i am thinking 2 4in aeros or 1 6in 2.0-2.2 cubes should be goodand i would probably set gain at 3/4 or so depending on your electrical and car factors
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
Old 09-06-2010, 09:49 PM
DurangoSPL's Avatar
0/11 sssssss61
this
Old 09-06-2010, 09:53 PM
jimmay's Avatar
0/11 ssssss481
Right now my gain is at half. Stock alt, 1 run of 0 gauge deep cycle in back and a sears gold battery(i know its going soon). I need to research aeros a but more...i have no clue how to figure out the tuning or how many to have in general. Thanks for your input though!
Sub Amp: AQ 3500
Subs:
Team DOA
Old 09-06-2010, 09:57 PM
TEAMLOWPOUNDERS
0/11 sssss3564
www.psp-inc.com go to tools
and you could probably turn it up more np
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
MTX amp input davidrforbus General Car Audio Discussion & Questions 8 08-23-2010 02:28 AM
need input. Highs On Bass Enclosure Discussion & Design Construction Help 27 06-10-2010 11:10 AM
need input kingmade08 General Car Audio Discussion & Questions 16 04-11-2010 10:44 AM
Ok, i need some input plz amcreynolds3 General Car Audio Discussion & Questions 5 08-01-2009 01:32 AM
