interchangable port help - Car Audio Classifieds!
Old 09-07-2010, 07:49 PM
0/11 sssss1380
Default interchangable port help
im going to be building yet another box, but i want to have interchangeable ports one for 50hz ( burping) one around 40hz ( for bassrace or something) and one in low 30s for daily ground pounding
but i dont have much room to work with, my MAX dems are only 37w 15t and 25D im not sure how i would go about doing hte interchangable port with the little room i have for port subs are taking up 26 1/2 of the baffle and the plan is with no port it will be tuned to 50hz then i add a port and tuned to 40 or low 30s so the box will essetially be tuned to 50 but i add the port and tuned lower if that makes any sence
i need ideas on how i would go about doin it!
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
round port converted to square port Ryan1126 General Car Audio Discussion & Questions 4 04-12-2010 04:46 PM
Mesh Over Port = Port Noise????? or Not crownvic02 General Car Audio Discussion & Questions 13 03-18-2010 04:25 PM
