Need to find a jig for my cheap router - Car Audio Classifieds!
Old 09-08-2010, 10:54 AM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
Default Need to find a jig for my cheap router
I have owned this thing for 2 years now or so. I have yet to use it, but now i need to. I have never used a jog before for cutting cirlces but now i need to also... anyone know of a jig that will work? Do all jigs work?
http://www.tylertool.com/skil23.html
Skil 1810 1-3/4 HP Fixed-Base Router
Skil 1810 Router Features:
  • Micro-fine depth adjustment - For precise cuts
  • Soft-grip handles - Added Comfort and control
  • Collet Lock - Eaiser bit changes
  • Wide base opening - Better visibility
  • 100% ball bearing construction - Added durability
  • Large depth scale - Ease to read
Skil 1810 Specifications:
  • Max. Motor HP - 1-3/4
  • Collet Capacity - 1/4"
  • Weight - 10 lbs.
  • Voltage - 120V
  • No Load RPM - 25,000
  • Cord Length - 6 feet
  • Amperage - 9
  • Certifications - UL
you probably wont like me
Old 09-08-2010, 10:59 AM
Whitymanne's Avatar
0/11 ssssss708
Jasper jig works great pretty easy to use also
Old 09-08-2010, 11:47 AM
ascitiesburn69's Avatar
0/11 sssss1645
Make one out of wood....Couldn't be easier and its more than likely free if you have scrap MDF or plywood at your house. Just cut a rectangle thats the width of your router and however long you want your circles to be and attach your router to it. Then turn router on and allow router bit to go through wood. Then all you have to do is take a tape measure and measure from the outside edge of router bit down the wood to the radius of the circle you plan to cut and put a nail or drill bit through it and BAM. Instant perfect circles. and the best part is the jig doesn't have to be straight or anything because as long as your measurement from bit to radius is correct, its gonna cut that size circle every time.
Team S.P.E.A.D.
Trunks FTW
Old 09-08-2010, 12:00 PM
upzaw2000's Avatar
0/11 ssss14427
i saw those... just not exactly sure how to hook it up to router?
Old 09-08-2010, 12:10 PM
upzaw2000's Avatar
0/11 ssss14427
not a bad idea
Old 09-08-2010, 12:19 PM
0/11 ssssss657
usually 3 screws. they already have multiple screw holes drileld for all different kinds of routers. it is the BEST jig out there
Old 09-08-2010, 12:22 PM
poundstone's Avatar
0/11 sssss1635
i just got a jasper jig and used it for the first time and it is really simple!! comes with a diagram showing how it works and instructions and also a diagram showing you have to mount it to your router and im pretty sure is universal but id ask if it will work with your model!! only thing i dont like about it is for some reason i have to mount it upside down for now because thats where the countersink is on the jig otherwise i scratch the wood! but easy fix just gonna countersink the other side and flip it over!!
2011 and 2012 usaci streetbeat 2 world champ
2012 2nd iasca advnw1 and lightweight bassboxing
2013 usaci mod 1001-2k world champ
2013 second meca mod 5
2014 mwspl adv 2 world champ
2014 meca mod 4 world champ
usaci streetbeat 2 world record holder b and k
usaci mod 1001-2k legal world record holder
mwspl adv 2 world record holder
first 160 ever on fusing at headrest in meca
poundstone's Avatar
0/11 sssss1635
mine mounts with 2 screws!!
Old 09-08-2010, 12:26 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
check out my random 2 pics in my user profile,.. You'll see a jig I made out of an old lexan clipboard on a pos router
who wants a nudel ride?
Old 09-08-2010, 12:34 PM
upzaw2000's Avatar
0/11 ssss14427
i saw that jig its what made me remember that i need one lol...
So i wonder if i can get a jasper jig at home depot....
router & jasper newarkbeast973 General Car Audio Discussion & Questions 31 04-08-2010 01:43 PM
router or rotozip? newarkbeast973 General Car Audio Discussion & Questions 17 03-19-2010 06:37 PM
Router Table Pioneer~Saturn Miscellaneous Build Logs 43 02-24-2010 04:44 PM
[FOUND] Router obrien202 Wanting to Buy (WTB) 24 06-05-2009 05:05 PM
Fix router vs Plunge router hifonicsviii General Car Audio Discussion & Questions 15 05-14-2009 11:38 PM
