6th Order Bandpass Information - Car Audio Classifieds!
Old 09-08-2010, 04:22 PM
Team Sundown/MD Sales Rep
0/11 sssss1351
Default 6th Order Bandpass Information
Im looking into changing the design of my truck up a little and would like some input. Originally I was going to run 6 SA-12s on 2 SAZ-3500s in a no wall setup. One of my friends who used to compete, Brian from Team BK, said I should try a 6th Order Bandpass with 8 12s. What do you guys think. He's pretty positive its going to get me up in the mid to high 50s on music. What are the pros and cons on BP designs? I have never really messed with them so I am unsure
-Jimmy
Team XS Power
/ Team Sundown / Team SHOK
MD, PA, DE Sundown Audio Sales Rep
SHOK Industries Dealer
Old 09-08-2010, 04:28 PM
got160s?'s Avatar
0/11 ssss13630
Bandpasses have better flat response.
They are also more efficient.
I'm going to be doing one this winter.
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
Old 09-08-2010, 04:33 PM
0/11 sssss1351
do they usually get louder then a standard slot port enclosure?
-Jimmy
Team XS Power
Old 09-08-2010, 04:41 PM
0/11 ssssss251
There is alot of things that go out of wack with these designs . not all drivers work well in these designs and they are not very forgiving in the airspace chambers. there is some write ups on the net for design and what drivers are known to work well in the higher psi that they are in. If done well and thought out they can be 10db or more over standard designs. Tapped horns also can do the same things if done correctly and play extremely low below 20hz. good luck and let us know how it goes
Old 09-08-2010, 04:45 PM
mega fatty
0/11 sssss6008
i had a tapped horn but only played to 37hz well, but could take 27000 theoretical rms before reaching the 10mm xmax was loud and had a very flat response well into 80hz.
6th orders are a bit more difficult to do so do some reading on them, i havnt experimented with them but ive heard they can be really picky
i also did a dcr enclosure for a sa8 and it worked ok but the port was to small for it, and it got big quick if i changed it at all, but those can have very high output as well
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-08-2010, 04:49 PM
0/11 sssss1351
Hopefully I will be happy with the 2 3500s on them..if not ill be upgrading to 2 4500s lol
-Jimmy
Team XS Power
Old 01-28-2011, 06:19 PM
0/11 sssss1351
bringing this back from the dead real quick.....in the 6th order, is the rear chamber tuned lower or the front? I cant remember
-Jimmy
Team XS Power
Old 01-28-2011, 06:43 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
rear chamber is tuned one octave lower than front chamber
less port area also
TeamGG
Team D.O.A.
Old 01-28-2011, 06:49 PM
0/11 ssssss467
i love my 6th order series tuned basnpass... be prepaird there veryyyyyy large boxes and the port area/ tuning isnt something ur gonna get 100% first shot.... useually ur looking at 3 x as much airspace in the frotn chamber compared to rear pending the 6th order u choice... ur looking at about a 8:1 ratio airspace to port area... and a 20:1 + port area to airsparce... also IE my rear chamber is tuned to 36hz and my fornts tuned to 76hz
Old 01-28-2011, 06:59 PM
0/11 sssss1351
What we are doing is a b-pillar wall with a center port. 8 12s firing into the port (4 on each side). Rear tuning is gonna be 28hz, front tuning 62. I have plenty of airspace so that isnt a big concern of mine. I was aware when I started playing with the idea of a 6th order I needed a ton of room lol
-Jimmy
Team XS Power
**WTT: 4th Order Bandpass for 3 10s"** 528hz Car Audio Trader (WTT) 12 08-09-2010 05:24 PM
4th order bandpass? wahvtec Enclosure Discussion & Design Construction Help 0 06-28-2010 05:53 PM
**FS: 4th Order Bandpass for 3 10s"** 528hz Wiring, Electrical & Other Installation Equipment 5 04-25-2010 08:38 PM
4th order bandpass users come in! murderedtahoe General Car Audio Discussion & Questions 19 04-18-2010 06:21 AM
Ported vs 4th vs 6th order bandpass sdelthon General Car Audio Discussion & Questions 20 10-19-2009 04:05 PM
