4 - 15's - Car Audio Classifieds!
Old 09-08-2010, 11:10 PM
0/11 sssssss46
Default 4 - 15's
I will be getting 4 15 inch memphis pr subs and would like to make a box
i have a 99 ford explorer and can use the whole trunk.
does anyone have any cb/ft - tuning frequency suggestions (primary focus being spl)
i would appreciate all the help i can get.
thanks. nate,
Old 09-08-2010, 11:15 PM
0/11 sssssss25
you need the Xmax of your sub (max Excursion) and what frequency you want to tune to, then you plug in the numbers on the site, and it'll tell you how much port area you need. the higher freq. you want to tune, the more port area you will need.
http://www.carstereo.com/help/Articles.cfm?id=31
Old 09-08-2010, 11:18 PM
0/11 sssssss46
thanks man,!!
Old 09-08-2010, 11:21 PM
0/11 sssss7816
That calculator is WAY off.
Atomic Loudspeakers
Audiotechnix
Old 09-08-2010, 11:25 PM
0/11 sssssss46
what would u recommend F3M4?
Old 09-08-2010, 11:29 PM
0/11 sssssss25
really. i was told it was one of the best ones.
Old 09-08-2010, 11:30 PM
0/11 sssssss46
ive never made a box before, so i need all the info i can get
id like it to resemble the design of meades.. (subs on top, port on back in middle)
Old 09-08-2010, 11:44 PM
0/11 sssssss25
i use the port calc. on car stereo, and torres box calc. from smd. to build my boxes. i'm no proffesional. but i'm happy with what has come from those plans i've made. sorry don't mean to give you wrong info.
Tags
box design, spl
CAN YOU MIX 2 KICKER CVX 15's with 2 KICKER CVRs 15's VanOn26s General Car Audio Discussion & Questions 17 08-24-2010 06:27 PM
(4) sdc2.5 15's vs. (2) mtx 9500 15's? Dbmonster General Car Audio Discussion & Questions 9 08-12-2010 01:11 AM
2 aq hdc3 15's vs 2 dc level 4 15's hdman87 General Car Audio Discussion & Questions 17 07-08-2010 08:49 PM
2x custom D1 15's + Dual 15's box w/ 10.5" Alum Flared Aero snb778 15" Subwoofers 13 02-08-2010 03:15 AM
(4) Memphis MOJO 15's reconed with FI parts WTTF for 2 B.A. 15's 18inchjeepin Car Audio Trader (WTT) 6 01-22-2010 05:30 PM
