Tuning center L slot port - Car Audio Classifieds!
Old 09-11-2010, 12:07 PM
apbt55's Avatar
0/11 sssssss76
Default Tuning center L slot port
I am working on a box design with a center L slot port. The box dimensions are as follows.
5 cubic ft net, shared chamber
38" wide, 18" tall, 24" deep.
the port is 5" wide and 16.5" tall and needs to be 40" long.
I want do a center port, but as you can tell it will need to be an L port.
My question has to do with the throat of the port. It will split behind each sub at the back. Should the back of the L and the straight portion back all summed equal the total reiquired lenght keeping it 4" in width. So in the diagram below the 2 red piece and the blue be a total length of 40" and be 4" wide?
Or should the rear throat be 2" wide and one side plus the straight length back equal the 40" of the port length, so in the diagram below 1 red portion plus the blue equal 40" with the red being 2" wide and the blue being 4" wide?
if this makes sense.
2004 nissan altima, 3.5L
275 amp DC power HO Alt, KHC1400 under hood. C&D UPS12-475-FR in back.
JVC Arsenal KD AHD59
AQ2200d (back up Soundstream PCA1500D)
MB Quart DSC4125
Crunch P1800.4
RF T1692, RF T1652-S in front, RF T1652 in rear door.
2 AQ SDC2.5-12 in ported box.
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
Slot port - Splitting it into two..?? westman995 Enclosure Discussion & Design Construction Help 4 11-08-2009 09:45 PM
4th order/slot port help king ranch Enclosure Discussion & Design Construction Help 26 08-03-2009 10:53 PM
Slot port and BBP craiggus365 General Car Audio Discussion & Questions 20 05-22-2009 02:40 PM
