box tuning and volume - Car Audio Classifieds!
Old 09-14-2010, 10:52 PM
xmikedxl's Avatar
0/11 ssssss189
Default box tuning and volume
Im new to building boxes and trying to figure some things out. One question i have is with the tuning of a box in relation to its volume and port size. For example, if you have a box with 12 cubes and deside to slot port it, as the length and port area decrease, the box volume increases as well. does this effect the tuning of the box?
Old 09-14-2010, 10:54 PM
ascitiesburn69's Avatar
0/11 sssss1645
Short answer= Yes.
Team S.P.E.A.D.
Trunks FTW
Old 09-14-2010, 10:59 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Yea...Well what do you want to know:
1. The smaller the port length, the higher the tunning for a given port area.
2. When figguring out your NET box volume(the real volume minus the port displacement(port takinup space and sub)) you should minus that displacement of the port(subwoofer too) and re calculate your gross box volume(volume of inside box reguarless of inside stuff).
BCAE.com has a calulator for that..but i dnt recc it...I'ts just there if u want to use.
Old 09-14-2010, 11:08 PM
0/11 sssss1645
x2 all of that.
Try and find a copy of Bass Box Pro 6. Best program ever.....
Team S.P.E.A.D.
Trunks FTW
Old 09-15-2010, 01:32 PM
xmikedxl's Avatar
0/11 ssssss189
for ex if you plan your box to be around 12 final cubes, how can you plan for port displacement when it is going to vary in size depending on what the box is to be tuned to wich in turn effects the cubes and tuning of the box
Old 09-15-2010, 06:15 PM
xmikedxl's Avatar
0/11 ssssss189
i guess you need to decide on a volume, build the port to your tuning, and then adjust the box volume to compensate for the port and sub displacement?
Old 09-15-2010, 09:43 PM
Novicaine's Avatar
0/11 sssss6135
Yea but you are actually right, for accuracy u also need to re calc the port length. Portarea, no!
An easy and most accurate way is to have the port outside the box..
Old 09-16-2010, 11:49 AM
SPL_II's Avatar
Teh Audioz Junkie
0/11 sssss3624
Originally Posted by ascitiesburn69 View Post
x2 all of that.
Bass Box Pro 6
Old 09-16-2010, 11:22 PM
xmikedxl's Avatar
0/11 ssssss189
i got it downloaded but it wont open i think its zipped and theres nowhere to extract what program can you use to open and install it?
Old 09-16-2010, 11:55 PM
SPL_II's Avatar
Teh Audioz Junkie
0/11 sssss3624
Winrar is what I used, I think thats what your talking about?
Box volume testing shizzzon (DC) 16 06-29-2010 10:10 PM
Volume going down by it self? davidrforbus General Car Audio Discussion & Questions 21 06-02-2010 04:14 PM
Must keep volume down ..??? Bushj311 General Car Audio Discussion & Questions 15 01-08-2010 07:48 PM
Box volume gbo559 General Car Audio Discussion & Questions 3 07-15-2009 04:51 PM
Enclosure volume forceww Tutorials & Quick References 7 08-05-2008 02:53 PM
