4th order guru's unite! - Car Audio Classifieds!
Old 09-16-2010, 11:59 PM
0/11 sssss4519
Default 4th order guru's unite!
so im building a 4th order for my friends expedition. but I havent built one sense 04!! we are using 6 PG RSD 12s on two AP1500s at .67. 270amp alt and two batts. I did some calculating and came up with. 7 cubes sealed gross, 23 ported with a 25x25x15.5" port at 45hz. 17cubes after port displacement and bracing. this is nothing more then a daily street beater. want to play down to about 25hz
Old 09-17-2010, 12:03 AM
rival904's Avatar
Loyal Member
0/11 sssss1023
You hiding from FLSPL or what?
Anyways, my old box was tuned at 43hz, and it played low, well, you heard it so you should know.
From what I have been reading, the larger the ported section, the more efficent the design, but the narrower the bandwidth becomes.
Hittin harder than Chris Brown.
Old 09-17-2010, 12:30 AM
0/11 sssss4519
no not really, but gmonk is the only guy to ever give any advice anymore so im looking elsewere. i could tune a little lower.
Old 09-17-2010, 12:31 AM
0/11 sssss4519
Old 09-17-2010, 01:22 AM
middle 2 will unload
Old 09-17-2010, 01:50 AM
0/11 sssss4519
suggestion for fixing that?
Old 09-17-2010, 01:51 AM
port on driver side and going side ways so the opening inside is on passenger side
Old 09-17-2010, 02:00 AM
0/11 sssss4519
then i will have no access to the subs for replacement/repair. what if i did the subs like this. that way they are all equal distant to the port.
Old 09-17-2010, 02:01 AM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Or possibly split the wanted port area into two ports and put them between the middle pairs of subs and the outside pairs (duno if you get what im saying )
and if youre worried about access you could make the section between these two ports removeable to get access to the subs...just a drunken thought lawl
Louder. Lower.
Team Tupperware
Old 09-17-2010, 02:04 AM
well it's either easy to get to replace or easy to blow and need to replace?
the second way looks better but might make all subs unload
HT guru's chime in get_low General Home Audio/Video 4 08-29-2010 12:44 PM
Plasma TV Guru's..In Here PLEASE! Craigzter General Home Audio/Video 14 07-18-2009 04:02 PM
where are my pyro guru's at? RollerDJ Off Topic Chat 61 07-06-2009 03:56 PM
Sled heads unite! sholiz Off Topic Chat 16 12-03-2008 04:57 PM
