Port help - Car Audio Classifieds!
Old 09-17-2010, 03:30 PM
0/11 ssssss267
Default Port help
I am going to build a box for 2 type R 12's this weekend. I want to try using pvc for the ports. Would I be better off using two 6" or one 8" port and why is one better over the other? Sorry if this is noob questions will be the first time I have used a round port instead of slot. I just wanna try something new.
Anything special that I need to know about using the pvc as a port over a slot port?
Thanks for any help or tips.
Enclosure will be 4cubes at around 34hz.
2004 Blazer Zr2
Old 09-17-2010, 03:32 PM
armymp90099's Avatar
Boomin' Bull
0/11 ssssss416
I personally would use the 2 6" Ports. Its less port area and would give more sub control. Below the tuning freq.
Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I die, you are forgiven." Such is the Rule of Honor.
Old 09-17-2010, 03:35 PM
0/11 ssssss267
I was liking the 2 6" idea also, I was also thinking one bigass 8" hole would look nice too. At the end of the day though I just wanna go with whatever is gonna work and sound best. They will probably see 600-700rms a piece if they will take it without getting stinky. I'm already pushing them kind of hard for what they are so wanna make sure I'm not gonna kill them with the wrong ports.
2004 Blazer Zr2
Old 09-17-2010, 03:38 PM
Boomin' Bull
0/11 ssssss416
Yeah I would stick with the 2 6" ports then. You could do the 8" if you wanted since you arent overpowering them too much but you would have to set your subsonic filter a little higher to keep sub control.
Old 09-17-2010, 03:39 PM
ascitiesburn69's Avatar
0/11 sssss1645
Thats quite a lot of port area for 2 12s considering the power you're running. More than likely its gonna be really peaky. You don't need 12-16sq in of port per cube when using aeros. 1 6" or 3 4"s would be fine.
Team S.P.E.A.D.
Trunks FTW
Old 09-17-2010, 03:40 PM
0/11 ssssss267
Sounds good, thanks for the help ArmyMP, Where are you an MP at btw? I was stationed at Fort Knox, Ky when I was in the Army. I was a tanker.
2004 Blazer Zr2
Old 09-17-2010, 03:42 PM
branham1127's Avatar
0/11 sssss2108
I do believe you're only supposed to use around 9" of port area per foot with aeros. A pair of 6" ports would be 14ish inches per foot
My build log:
Uninterrupted Build log:
New Cobalt build log
Old 09-17-2010, 03:43 PM
0/11 ssssss267
Hmm, well if anyone else can chime in that has some enclosures under their belt I'd love to hear what you guys would build. I'm far from being an expert.
2004 Blazer Zr2
Old 09-17-2010, 03:49 PM
0/11 sssss1943
The box im using right now for my 2 12's is about [email protected] with a single 6" port.
and a single 8" port isnt more port area than 2 6"
Old 09-17-2010, 03:57 PM
0/11 ssssss267
A single 6" doesnt seem like it would be enough for 2 12's, but again I am used to using slot ports. Anyone else wanna chime in on what they would recommend?
2004 Blazer Zr2
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
round port converted to square port Ryan1126 General Car Audio Discussion & Questions 4 04-12-2010 04:46 PM
Mesh Over Port = Port Noise????? or Not crownvic02 General Car Audio Discussion & Questions 13 03-18-2010 04:25 PM
