4th or 6th order help - Car Audio Classifieds!
Old 09-19-2010, 02:24 AM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Default 4th or 6th order help
currently have 2 btls in a 4th order and was looking at adding 2 more...maybe even going with different subs...what would be the ideal ported to sealed numbers? also i would like to keep my port around the same size opening.(dont really wanna cut any more of my cab out than i have to)..i have around 20-25 cubes..thinkin about makin a removable top so it will be easier to remove the subs...just really wanna know if i have the space or not..anybody?
2000 2dr Blazer
Old 09-20-2010, 03:12 PM
0/11 sssss5201
come on guys someone knows a little about this...lol
2000 2dr Blazer
Old 09-20-2010, 03:15 PM
0/11 ssss31247
yes you have the room.
The same size port in a larger chamber will need to be shorter to keep the same tuning you have.
the rest depends on the exact specs of the speakers
Old 09-20-2010, 05:39 PM
0/11 sssss5201
well what i have now doesnt hit the lows like i would like it to...the subs seem to bottom out to quickly.
well i was thinkin two more btls...but honestly would rather have something with a smaller diameter magnet....these are a bish to get in. lol
also looking for subs that perform well in 4th orders...might hit up PSI to make me some any suggestions?
2000 2dr Blazer
Old 09-20-2010, 05:44 PM
J&T DESIGNS's Avatar
0/11 ssssss791
1)Sealed chamber is to big.
2)Sa 12's
db Revolution
J&T DESIGNS
Old 09-20-2010, 06:39 PM
0/11 sssss5201
I wanna say the sealed chamber is .7 ...hold on and i will put the deminsions of box on here. also would 2 sa12's be louder than 2 btls? lol they triple the rms rating on them..i was thinking along the lines of nightshades, level 5's, wardens, tc 5200's( I WISH) lol, and BTL's, Maybe even Mayhems??
2000 2dr Blazer
Old 09-20-2010, 08:06 PM
0/11 sssss5201
2000 2dr Blazer
Old 09-22-2010, 07:07 PM
0/11 sssss5201
nobody?
2000 2dr Blazer
Old 09-22-2010, 07:43 PM
TEAMLOWPOUNDERS
0/11 sssss3564
Sealed chamber is too big and your tuning is prolly two high...and btls perform really well in 4th order I'm not shure why your not hitting lows but if you want more lows I would upgrade to mabey a larger size sub could work?
CAR: 2008 f250 6fo
BATTS: 2 100ah
SUBS: 1 Hybrid 18
AMP: 1 Sundown SAZ3000s
Old 09-22-2010, 07:46 PM
0/11 sssss5201
well if my sealed portion is to big then thats probably why its not hitting the lows as good...and i can only fit a 12 in my bed under the cover..also its tuned to 43 hz...that should hit the lows very well..
2000 2dr Blazer
4th order box help constantprojects Enclosure Discussion & Design Construction Help 7 08-26-2010 11:18 AM
2 4th Order 10s D4 GearGuy2001 Wanting to Buy (WTB) 10 07-05-2010 09:31 AM
anybody done a 4th order in an suv? toolmaker Enclosure Discussion & Design Construction Help 2 12-14-2009 09:32 PM
In order fatpat1080 Uncensored Off Topic 26 07-01-2009 11:17 AM
