wrappin a box with carpet? - Car Audio Classifieds!
Old 09-19-2010, 02:51 PM
0/11 ssssss796
Default wrappin a box with carpet?
i just built a couple of boxes and wanting to wrap them with carpet. anybody have any tips or maybe a step by step guide? i was lookin at my prefabed box and it is seamless how do i achieve this? any input is apreciated
Old 09-19-2010, 02:58 PM
0/11 ssss31247
There was a guide in the tutorials section. {not sure if it still is}
I use 3M super 77 spray glue {I don't get along with Super 90}
and an actual carpet knife. {very very sharp... dangerously sharp.. and double sided}
[note.. actual carpet blades are thinner and sharper than utility blades]
Using one piece of carpet long enough to go more than all the way around the box and wide enough to cover more than half the ends, I just carpet the long sides and then fold in the ends and cut through the layers making the seams an X on each end of the box.
Many builders make the ends of their boxes have indentations so the very edges can be wrapped and the indentation can be one solid piece of carpet so it looks perfectly seamless.
Old 09-19-2010, 02:59 PM
0/11 ssssss185
theirs a tutorial on this and just about anything in the tutorials and quick reference section
Old 09-19-2010, 07:29 PM
0/11 sssss4519
elemental designs website has an awesome video on how to do it
Old 09-19-2010, 07:40 PM
0/11 ssssss149
I tried super 77, didn't work To hot here in AZ I guess. I use weldwood contact cement that come in the green can. Works great out here in our 100 degree plus weather.
Old 09-19-2010, 07:52 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
The key to Super 77 is to spray both surfaces and then let it sit for about a minute before you join them.
Like the other said check out the tutorial section for a couple of threads on carpeting.
/ CAAA Member #2 /
Old 09-19-2010, 08:01 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
good place to start is on e d's website. great vid actually. and i use a certain spray adhesive labeled 1080 but i cant remember the company that makes it. shit is great. also if you have a router with an upcut bit you can actually do rabbited edges once the box is built and all the corners are flush. make a jig out of 1/4" mdf or 3/4" scraps, just something with a straight edge. set your router to an acceptable heighth with the 1/4" upcut but and run the router right alont the seam up against the secured jig (using clamps) wahbam you have a seem to make a nice prof. look. really time consuming that way, but works.
Also make sure to buy more than you need as you may mess up
SHABAM
Carpet gbo559 Enclosure Discussion & Design Construction Help 8 04-11-2010 08:34 PM
How to carpet a box 101 Slammintriple6 Tutorials & Quick References 0 03-20-2010 05:13 PM
How to put carpet on a box Ccab81 Tutorials & Quick References 4 03-15-2010 11:02 AM
carpet help RidnClean General Car Audio Discussion & Questions 4 08-20-2009 02:03 PM
How to Carpet a box SPY Tutorials & Quick References 2 10-01-2008 11:36 AM
