annother 4th order help - Car Audio Classifieds!
Old 09-20-2010, 04:12 PM
mega fatty
0/11 sssss6008
Default annother 4th order help
so i just got 12 polk dxi 12's, looking to do a 4th order
i was thinking 15cf sealed, 30cf ported tuned to 35, 480sq" of port
i modeled it in winisd and it seemed to have a large peak around 30hz and dropped down 3db at 40hz and stayed flat after that,
is there a way to get the nice peak i had at 30hz but keep a decent bandwidth?
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-20-2010, 04:20 PM
0/11 ssss31258
Tune it higher. 50 or 60hz is good
4th order tuning is centered on the bandwidth which it will reproduce.
When you tune it low {30hz} you are cutting off the efficient bandwidth of the speakers. [efficient bandwidth of most subs is from 30hz to 60hz]
Tuning high still hits the lows because unlike a vented enclosure, the low end is not cut off. [that's why 4th order plays the lows awesome]
Old 09-20-2010, 04:25 PM
mega fatty
0/11 sssss6008
ok i will try to model it a bit different, but possibly going for a 6th order, or a dcr? i did one dcr and it played ok, but didnt really have the low end i was looking for, (was first one possibly just not tuned low enough) but how would i go about a decent 6th order? 2:1 for each tuning chamber?
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-20-2010, 04:57 PM
mega fatty
0/11 sssss6008
so if i do decide to do a 4th, im on the right track with the 2:1 and i will just have to raise tuning to around 45ish?
07 mazdaspeed3
rd d9 @ .5ohm
Old 09-20-2010, 05:39 PM
J&T DESIGNS's Avatar
0/11 ssssss791
What type of 4th order design are you looking for? Will this build be for music or pure SPL? The 2:1 ratio is nothing more than a rule of thumb, the best way is to stick within 1 octave and keep building it in or out until you stop getting louder. The key to any build is efficiency in my eyes.
db Revolution
J&T DESIGNS
Old 09-20-2010, 08:12 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
explain please
2000 2dr Blazer
Old 09-20-2010, 09:15 PM
0/11 ssssss791
Originally Posted by treylittlefield View Post
explain please
1 octave would be, sealed chamber 30hz front chamber 60hz. building in or out is as it sounds you just build the loading wall or your sealed chamber in or out.
db Revolution
J&T DESIGNS
Old 09-20-2010, 09:23 PM
0/11 sssss5201
Ah I see....I'm guessing to tune the sealed portion would be by the volume correct?
2000 2dr Blazer
Old 09-20-2010, 09:27 PM
0/11 ssssss791
Yes
db Revolution
J&T DESIGNS
Old 09-20-2010, 10:05 PM
0/11 sssss5201
gotcha. hmmm so would u tune sealed to 30 and ported to 60? im confused
2000 2dr Blazer
4th or 6th order help treylittlefield Enclosure Discussion & Design Construction Help 28 10-14-2010 05:48 PM
4th order box help constantprojects Enclosure Discussion & Design Construction Help 7 08-26-2010 11:18 AM
2 4th Order 10s D4 GearGuy2001 Wanting to Buy (WTB) 10 07-05-2010 09:31 AM
In order fatpat1080 Uncensored Off Topic 26 07-01-2009 11:17 AM
