Single 15 dual slot port or dual L port box - Car Audio Classifieds!
Old 09-21-2010, 03:14 AM
0/11 ssssss132
Default Single 15 dual slot port or dual L port box
Ok so i'll be building an enclosure for a single 15" Rockford Fosgate T2 (new model) powered by a T1500bd1. Tuning will be around 32 hz with 3 cubes net volume. I've build L ported and aero ported boxes and i could use some help/suggestions. Thanks guys.
Old 09-26-2010, 06:35 AM
0/11 ssssss132
Alright then, so i guess im going with a single L port. Nevermind.
Old 09-26-2010, 06:45 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
People prefer an aero port for two reasons, the flare elminates some possible port noise, and the fact they are very easy to change tuning on. Some beleive it is louder then a slot port while others dont. I truly beleive its all application dependent. If you know what you want and arent worried about making changes I would do a slot port and go over it with a nice round over bit to give it the flared effect.
Old 09-26-2010, 06:54 AM
0/11 ssssss132
I definately prefer aero ports, with flared ends of course. I won't build another port without having it flared ever again. The problem is the guy i'll be building the box for wants 2 ports, one on each end. If it was up to me i would definately do a flared aero port. My tools are very limited so i'll be rounding out the port using a dremel, it just takes longer. I guess i'll make a design for an L port and split the internal port air space in two and have 2 slot ports or even 2 L ports. Had a box built for his friends' using an aero port and it worked out great, but hey, he wants what he wants.
Dual kerfed port enclosure build for 4 15 rockford t1's twisted Build Logs 27 09-01-2010 05:53 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
Slot port and BBP craiggus365 General Car Audio Discussion & Questions 20 05-22-2009 02:40 PM
