Port distance from rear hatch - Car Audio Classifieds!
Old 09-22-2010, 03:07 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Default Port distance from rear hatch
Now I've heard all sort of things about how for how far the port of a box should be away from a hatch, you know, some say the diameter of the port or half of the diameter of the port, but yet I've seen as little as 2 inches work and be crazy loud. So I'm wondering, how far? Say if I had a box that had 4 6" aeros at the bottom, how far away should it be from the rear hatch? 2", 4", 6", or what? Every inch closer I can make it, the more room I have else where. Vehicle is 03 Exploder.
Old 09-22-2010, 03:09 PM
mega fatty
0/11 sssss6008
i would do it no closer than 3", 1/2 the port diameter
07 mazdaspeed3
rd d9 @ .5ohm
LivinLoud08's Avatar
0/11 sssss1318
very good question, i'd like to know the answer as well. im sure most of the answers will be to test and see what works best for your application
sold to: willie3719, VanOn26s, papito,ralphysounds,ingramk03, BaseHead, Luis Mendez, davidforbus, RustyWCA, alviso913
That's right. And I walk the walk... no reservations here. If I offended someone, oh well, never said I was nice, just good.
Old 09-22-2010, 03:12 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
The reason I ask is I'm probably squeezing 2 18"s in there, and need every inch I can get.
Old 09-22-2010, 03:42 PM
0/11 sssss1318
im actually trying to do the same thing in a 4runner. also thinking of running 4 6" aeros myself and i know what you mean about trying to sqeeze all you can in such a small space
Old 09-22-2010, 04:16 PM
0/11 ssssss657
I would try to do the diameter of the port. i have had boxes up real close(inch or 2) to my hatch and didnt notice the difference is sound to the ear atleast.
Old 09-22-2010, 04:56 PM
Derrick824's Avatar
0/11 sssss2362
Feedback Score: 56 reviews
A good rule of thumb is to stay the diameter of the port away. This is a test & tune type thing though. I know when using 4" ports in my Explorer it didn't matter if they were 2" or 6" away the score didn't change. Rebuilt for 6" ports and they needed to be exactly 3" away to work correctly. Any more or less and my score dropped by 1.5db.
Old 09-22-2010, 05:00 PM
armymp90099's Avatar
Boomin' Bull
0/11 ssssss416
That's what she said.
Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I die, you are forgiven." Such is the Rule of Honor.
Old 09-22-2010, 06:08 PM
0/11 sssss1318
damn thats a big difference
0/11 sssss1318
Best distance for ports from rear hatch? 87linkin General Car Audio Discussion & Questions 10 07-10-2010 04:02 PM
How far away from hatch? Mgcauctions09 General Car Audio Discussion & Questions 11 05-04-2010 01:47 PM
CAN TRICK! + Some Flex+ Distance Test....DD 3518's twistedchild420 Car Audio Videos 17 04-17-2010 10:43 PM
Port through rear deck, 4th order? Jh8909 Enclosure Discussion & Design Construction Help 11 02-06-2010 01:10 AM
