Too little port area: Is it ever good? - Car Audio Classifieds!
Old 09-24-2010, 01:56 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
Default Too little port area: Is it ever good?
I was wondering if there were any advantages to having less port area than needed? I know that if the port area effects how loud a sub can get, but can it also control the cone from over-excursion or help with power handling, similar to making an enclosure too small?
Old 09-24-2010, 02:06 AM
HiloDB1's Avatar
0/11 sssss3158
Umm it will reduce the length/volume of port needed.
Old 09-24-2010, 02:10 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
That's it? I knew that was an option, but I expected a little more than that. I live in a fantasy world
Old 09-24-2010, 02:16 AM
HiloDB1's Avatar
0/11 sssss3158
Well beyond that there is no real benefit. Any positive would be outweighed by the negatives.
Old 09-24-2010, 02:29 AM
No, I'm not dead
1/11 sssss8128
It can make some hellaciously loud noise at high volume. If, ya know, you want to impress people with the air in your ports reaching near sonic velocity.
Old 09-24-2010, 02:40 AM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Noted
Mat, you make everything bad sound horrible.
Thanks guys, I was just thinking about this, and wanted some feedback.
Old 09-24-2010, 03:23 AM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
It won't work right reguarless of tunning, it could cause mechanical failure, and noise.
Old 09-24-2010, 03:28 AM
this seams to be a touchy subject when I get involved
Old 09-24-2010, 03:42 AM
Novicaine's Avatar
0/11 sssss6135
All I know is that from tests, your sub response will not be what you expected. It's like building the perfect sealed box volume, but having it leak.
Old 09-24-2010, 04:23 AM
No, I'm not dead
1/11 sssss8128
Originally Posted by 1ndatrunk View Post
Noted
That's because bad sound is horrible.
How Much Port Area Redrider1 General Car Audio Discussion & Questions 12 06-22-2010 12:41 AM
port area zero1200d General Car Audio Discussion & Questions 11 05-17-2010 08:34 PM
help me with port area jwesenick79 Enclosure Discussion & Design Construction Help 5 01-08-2010 01:22 PM
port area lantz Enclosure Discussion & Design Construction Help 10 12-27-2009 03:03 AM
