What box specs? - Car Audio Classifieds!
Old 09-24-2010, 01:03 PM
0/11 sssssss27
Default What box specs?
Currently, I've got two Type R's in a sealed box at 1.2 cu ft per chamber. I want to switch to a ported box for loudness, can anybody recommend a pre-made ported box that would be good for these two subs? Making my own isn't an option, I don't even have the tools to do so. And maximum width I can fit is about 33". Still hoping to maintain a level of sound quality so what should I tune the box to?
Old 09-24-2010, 01:13 PM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
most prefab boxes are tuned around 38 - 45 hz......probox makes good boxes and obcon and fatbox if u have the cash make the best IMO!
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 09-24-2010, 01:25 PM
0/11 sssssss27
Sorry if this is a stupid question, but I don't fully understand tuning of the box. Would I get better quality out of a lower or higher tuned box?
Old 09-24-2010, 01:32 PM
0/11 sssss8594
Feedback Score: 55 reviews
get a box made...dont get a prefab box...and its not a matter of quality of tuning...if u like gutwrenching bass and DONT care about low end, tune higher...tuning higher also USUALLY will give u better numbers on a tl...but if u like low tones, like anything jeezy for example, tune lower, like 32-35hz...when u do tune higher tho, when you get a tone that drops below the box tuning, your risking damaging your subs...higher tuning is mainly designed fo comps
Enclosures
Old 09-24-2010, 01:41 PM
0/11 sssssss27
I know custom made are better, but I'm kinda hard on cash, and pre-mades are usually cheaper.
Old 09-24-2010, 01:44 PM
0/11 sssss8594
look around on the forum, im sure theres sum1 on here that lives near u that can help...put out a thread "who lives in Indiana and knows how to make a box?"...you'll be sooo much happier than a prefab box
Enclosures
Old 09-24-2010, 01:47 PM
0/11 sssssss27
Alright, thanks.
Old 09-25-2010, 04:14 AM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Just a thought, sometimes people on here and other forums, sell used boxes which may work for you. Determining the if box size and tuning would fit your needs is a concern but would be with a prefab also and that is what asking questions on the forum is for, learning from the experience of others.....
amp specs anyone ? xjoeyc23x General Car Audio Discussion & Questions 2 06-06-2010 09:31 AM
Help with Sub Box Specs whitedragon551 General Car Audio Discussion & Questions 10 06-04-2010 05:30 PM
IA DP gap specs grimreper912003 (Fix My Speaker) 12 04-08-2010 06:56 PM
specs korey_hofer General Car Audio Discussion & Questions 12 12-28-2009 06:46 AM
PSI- need specs for the 3hp snoopysnooper (Fix My Speaker) 4 06-01-2009 05:56 PM
