port/box help - Car Audio Classifieds!
Old 09-28-2010, 02:00 PM
0/11 sssss1380
Default port/box help
ok so, i want to make a new box but... im running into port problems
max dems are 36/37W 14T 25D
2 12s on 7k
current box is triple baffled 36w 14t 25d port is a 6" slot port 17 1/2 long tuned to 45 IIRC
now my problem is i get port noise and port compression soo new box needs a bigger port BUT i dont want to tune any higher and when the port bends i get loading issues on the sub closer to the port
so, what could i do to tune lower but still have lots of port area and no loading problems?
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
1200A of singer power
12 Fi SSDs fully loaded
[email protected]
Old 09-28-2010, 03:13 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
port down the middle
or
have some of the port external
TeamGG
Team D.O.A.
Old 09-28-2010, 07:03 PM
0/11 sssss1380
middle port.. im likin that idea right now lol
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 09-28-2010, 08:25 PM
Decaf's Avatar
0/11 sssss3460
whats the sub displacement and bracing u will use?
TeamGG
Team D.O.A.
Old 09-28-2010, 08:31 PM
Decaf's Avatar
0/11 sssss3460
its hard to believe that with ~18sqin/cuft that u have port noise
thats crazy, lol
TeamGG
Team D.O.A.
Old 09-28-2010, 08:35 PM
memphis87's Avatar
0/11 ssssss171
that is really crazy
2 18" AQ HDC4's
1 crescendo bc5500 @1ohm
1 Crescendo Concerto 1100.4
6 crescendo pwx's and 4 vifa 1" tweets
Official DB drag score 151db @ 38hz
youtube: hulbert87
Old 09-28-2010, 08:44 PM
0/11 sssss1380
sub displacement is .4 for both IIRC bracing... what ever is needed
i even rounded the the port over pretty good to get rid of port noise...
i have gains set for vol 52 and at about 48 you can hear port noise and then port compression at 52
it gets kinda annoying lol
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 09-28-2010, 08:54 PM
Decaf's Avatar
0/11 sssss3460
have u tried pluggin it to both reduce port area and lower tuning
like with a towel wrapped in packing tape.... i know ur port does not bend so give it a try and see what happens
maybe u have too much for the power and u need more cone control
TeamGG
Team D.O.A.
Old 09-28-2010, 09:10 PM
0/11 sssss1380
no i got no MDF thats tall enough i dontt hink i dont loose cone control i dont think
dont you need more port for more power?
Team A$$hole
1998 chevy extd cab
4 SAZ 4500s
[email protected]
Old 09-28-2010, 09:14 PM
Decaf's Avatar
0/11 sssss3460
well what are the subs doing when u say there is "port compression"
have you oscoped the amp at those volume numbers? maybe 48-52 is where clipping starts and thats what u are hearing since u are so far past rms, lol
TeamGG
Team D.O.A.
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
round port converted to square port Ryan1126 General Car Audio Discussion & Questions 4 04-12-2010 04:46 PM
Mesh Over Port = Port Noise????? or Not crownvic02 General Car Audio Discussion & Questions 13 03-18-2010 04:25 PM
