New kid needs some help. - Car Audio Classifieds!
Old 09-30-2010, 03:29 PM
0/11 sssssss26
Default New kid needs some help.
I've always been in to car audio, Well since I was 11. And now I want to make a box to go along with a 12" pioneer and a 800 watt pioneer amp. (I'll add the links at the bottom.) Any way, my question is, Do I have to go by the factory recommended box specs? Because 1.5 cubic feet seems a little small and I'm trying to get a decent amount of boom from this little guy. Pretty much what I want to do is run the sub at 2ohms and run a ported box at about 35 hertz. So what are your thoughts?
Sub: http://www.pioneerelectronics.com/PU...5C%7CDVC?tab=B
Amp: http://www.pioneerelectronics.com/PU...ries/GM-D7500M
Old 09-30-2010, 03:41 PM
0/11 sssss6075
As surprising as this may sound, manufacturers do actually have a fairly decent idea of good enclosure sizes. I'd say take their word for it, or get the T/S and model up your own enclosure.
Old 09-30-2010, 03:44 PM
armymp90099's Avatar
Boomin' Bull
0/11 ssssss416
1.5 net should be fine for that setup. Maybe 2 at most.
Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I die, you are forgiven." Such is the Rule of Honor.
Old 09-30-2010, 03:48 PM
0/11 sssssss26
Ok, So I should be fine with factory specs. Thanks guys.
Old 09-30-2010, 04:48 PM
0/11 sssssss26
Ah one more question. What kind of port should I use? I was thinking Just a slot but now I'm thinking of a L port. Any ideas?
Old 09-30-2010, 04:51 PM
0/11 sssss6075
Same thing. L occurs when you need more port length than the box dimensions allow.
Old 09-30-2010, 04:55 PM
0/11 sssssss26
Oh ok cool, thats what I thought. I just didn't know if it helped with air flow or not.
Old 09-30-2010, 05:01 PM
0/11 sssssss26
Hmm, I've been messing with some box calculators and it looks like I'm gonna have to run a port that is 1" wide to get 35 hertz. Now that just seems like there may be some port noise, Do you think it would be better just to run sealed box?
Old 09-30-2010, 05:05 PM
0/11 sssss6075
Run a wider port. Or use a 4" aero.
