15s ported VS 18s sealed - Car Audio Classifieds!
Old 09-30-2010, 10:04 PM
0/11 sssss4519
Default 15s ported VS 18s sealed
Ok so my friend has a 240sx, hes fixing to go on deployment and wants to do something a little different with his ride prior to leaving. I guess so he has something to look forward to coming home to. so right now hes got 3k rms to work with and his ultimate goal is a good hair trick. I was thinking of wallin the car out sense its a trunk car and doing two mach5 IXL 15s, with as much port tuned to about 30-32hz. or perhaps two IXL 18s sealed. kinda stuff on what the do. help please
Old 10-01-2010, 11:46 AM
0/11 ssssss149
Why not build the motor etc? Just sayin. And I vote 15's ported, gonna be a tight squeeze no matter what you do.
Old 10-01-2010, 11:50 AM
0/11 sssss7816
Sealed probably aren't going to move enough air to make hair move bro.
Atomic Loudspeakers
Audiotechnix
Old 10-01-2010, 12:12 PM
0/11 sssss4519
He's already got some wierd motor in with a rather large turbo but sound is more important to him then speed. I was thinking bout trying to get a pair or re mt 15s to put in there
Old 10-01-2010, 12:20 PM
0/11 ssssss149
I gotcha man, could do a pseudo bandpass...Just do a sealed wall, then use the remainder of the cab as the ported side. I guess the cab would be your ported cu ft, and the window area would be the sq in of port. If you got the numbers right that should work. Anyone else wanna chime in on this theory?
2 15's sealed or 1 15 ported? spencerearl1996 General Car Audio Discussion & Questions 3 09-19-2010 11:36 AM
4 fi q 12's ported or 6 12s sealed? username General Car Audio Discussion & Questions 18 07-07-2010 11:52 PM
Ported or Sealed??? joebobclark Enclosure Discussion & Design Construction Help 3 06-23-2010 07:29 AM
Ported vs Sealed Help! agrimm34 General Car Audio Discussion & Questions 1 01-08-2010 09:57 PM
Never went from sealed to ported, big difference? hornedfrog1985 General Car Audio Discussion & Questions 23 07-24-2009 12:08 AM
