Tuning Freq. for DD 2512's - Car Audio Classifieds!
Old 01-24-2009, 11:53 PM
0/11 ssssss384
Default Tuning Freq. for DD 2512's
I'm designing a box for my 2 DD 2512's and I'm reading all the info I can find, but I'm hoping someone on here has experience and can tell me:
Would a 30Hz tuning frequency have a noticeably lower extension than a box tuned to 40Hz for these subs?
DD says that the subs can play well below the box loading point, but I want to know how true that is. This is going to be a daily driver and I love really low bass so I want to know from someone with experience what the best tuning frequency would be.
Thanks,
-Ryan
Old 01-24-2009, 11:56 PM
bones22's Avatar
0/11 ssss12257
with most DD stuff stay between 38-42hz
myy 99z was tuned at 36hz and i wish i had gone with 40
Old 01-24-2009, 11:58 PM
0/11 ssssss384
I'm going to go with the largest box recommendation on DD's site at 5 cubes, so should I just use the 80sq x 18 inch port that they recommend as well?
Old 01-25-2009, 12:41 AM
No, I'm not dead
0/11 sssss8128
Yeah, just build it according to their recommendations. DD are SPL woofers, they wouldn't know SQ if it bit them on the face so trying to run one of their subs in a box tuned below 40hz is pointless. They even admit it on their site.
Old 01-25-2009, 12:52 AM
0/11 ssssss384
Have you ever used a DD sub?
Old 01-25-2009, 03:53 AM
No, I'm not dead
0/11 sssss8128
No but a SQ sub will have a FS way lower than 38hz and the MFG will recommend tuning the box under 40hz. 38hz FS and 40hz tuning = SPL sub plain and simple.
Go onto DD's site and every box they recommend is tuned to 40hz and sealed boxes are warned against. Now, you tell me if they build SQ subs.
Old 01-25-2009, 05:20 AM
0/11 ssssss384
They aren't true SQ subs in the sense that they don't go very low, but they are very accurate in sound reproduction. They have great transient response and have a tight, punchy sound. If you read why they have the boxes tuned to 40Hz it's because the suspension is tight enough to remain loaded below box tuning, past 30Hz. I simply wanted confirmation of this by someone that has had experience.
I will agree that they aren't made for SQ but saying they are only for SPL when you've never heard one is ludicrous.
Old 01-25-2009, 05:28 AM
No, I'm not dead
0/11 sssss8128
If it's not a SQ sub it's an SPL sub. It's either fish or fowl, it can't be both. Well, with the exception of stuff like Volfenhag and Visonik which aren't either, they're just garbage.
Look at it like this, if a sub cannot produce usable bass below 30hz it's not a SQ sub. If a sub is made for competition (which the DD subs are) and can't compete in SQ because they won't play below 30hz then what are they classed as? SPL or bassrace which is essentially an offshoot of SPL competing.
I don't have to hear a duck to know that it quacks.
Old 01-25-2009, 05:37 AM
0/11 ssssss384
I'll download some test tracks and get back to you later today because I don't have exact numbers on where my subs roll off. I do know that it is below 30Hz though.
Old 01-25-2009, 05:49 AM
No, I'm not dead
0/11 sssss8128
Ideally, for SQ, true SQ mind you, you should have flat response from 20hz all the way up to the filter frequency of the sub amp. I can tell you right now that a sub in a box tuned to 40hz won't be flat. There will be a large hump in the response curve centered around 50-60hz. I've plotted my fair share of enclosures.
Have you got the T/S parameters for your subs? I'll be happy to plot them and show you what I'm talking about. I'd also like to see if there's anything to DD's claims that their subs won't work well with lower tunings.
Rat style tuning snikwad General Automotive Chat 67 03-15-2009 05:23 PM
Box tuning? 98AckCL23 Talk with the staff 2 01-13-2009 11:00 AM
port tuning? 98AckCL23 Enclosure Discussion & Design Construction Help 5 01-13-2009 01:00 AM
[COMPLEX] Determining the Tuning Freq. of a Vented Enclosure? danteBirosel Tutorials & Quick References 0 11-12-2008 01:49 PM
