box for DD 2512 help - Car Audio Classifieds!
Old 10-06-2010, 12:54 AM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
Default box for DD 2512 help
Ok so just baught a DD2512 and i need some more box designs. its going in the back of a MINI cooper S. my max dimensions are 30x10x19 so i think thats just shy of 2.5 ft3 so not much space to work with. it will only be getting about 500 RMS until i can afford a bigger amp. so how much space and what freq. id like to use a 3" aero since i already have 1. but slot wouldnt be to bad weither. any suggestions besides getting a bigger amp LOL
thanks
Adam
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 10-06-2010, 08:03 AM
Ajax_6154's Avatar
0/11 sssss2369
going to bed bump
Old 10-06-2010, 04:43 PM
Ajax_6154's Avatar
0/11 sssss2369
going to work bump. come on guys are there no box designers here
Old 10-06-2010, 04:53 PM
FLAstrongman's Avatar
0/11 sssss1156
Feedback Score: 21 reviews
punch those dimensions into the RE calculator. Put the port width at 3". L2 at 0. This gives you 36hz tuning, and right at 2cu ft after your sub displacement. Because of the small port area, you'll need to roundover the port mouth.
Custom box builds for FL:
Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee, xx-wade-xx, traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
Old 10-06-2010, 07:03 PM
Ajax_6154's Avatar
0/11 sssss2369
yeah i love that calculator used it a few times with great results
Old 10-07-2010, 11:33 PM
Ajax_6154's Avatar
0/11 sssss2369
ttt
Old 12-12-2011, 03:18 PM
0/11 sssssss26
i could design you a box if you'd like. just shoot me a pm on here or check out my facebook page for more info.
Old 12-12-2011, 03:24 PM
surreal's Avatar
0/11 sssss2489
Id also be happy to design you a peoper enclosure. Please follow the link in my signature to fill out a request on my website.
Old 12-12-2011, 03:25 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
guys this is more then a year old lol
Old 12-12-2011, 03:29 PM
Loudforce Distributor.
0/11 ssssss535
With that space i wouldn´t go with a slot port, it takes way too much space, aero is definitely your best choice. Said that, 3" aero is WAY too small for that kick ass sub, i would try to use AT LEAST 2 of them , and as my boy strongman said, flares it´s a must be ! if not, you might get a lot of port noise.
If those were my measures, i would definitely get 2 4" aeros 17" long each one (full lenght original aero) , that would give me around 2 c/f and 38 hz tuning after displacement, if not, 2 3" aeros around 11-12 long each one depending on the kind of music you like, that would give you around 2.2 c/f and 35 hz tuning.
Since you only have 19" to fit the aeros, you might have to use them a little bit outside of the box (if you use the 2 4´s option) , if you go with 2 3" aeros then you don´t have any problems
Aq sdc2.5 12" = dd 2512??? SQL Monte General Car Audio Discussion & Questions 12 01-05-2010 01:26 PM
JL W3 vs DD 2512 Drunken.Swagger General Car Audio Discussion & Questions 5 12-01-2009 02:17 PM
