RE/PSI 15s, 12cubes and 4500w - Car Audio Classifieds!
Old 10-06-2010, 10:35 PM
0/11 sssss4519
Default RE/PSI 15s, 12cubes and 4500w
so I have 12cubes after the subs and all thread bolts we are using for bracing. now my question is do you guys think this is enough port. its honestly the largest i could go and still keep a relatively low tuning. 33hz. the port is 4x25x17 leaving a 6" gap from the port to the rear wall, and about 10" at the top. this is a wall in a 240sx
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 10-06-2010, 10:42 PM
0/11 sssss4519
resolve Vas/28.32 =
result of that +1
Old 10-06-2010, 10:47 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
what size all thread?
Old 10-06-2010, 11:06 PM
MisterGrubbs's Avatar
0/11 sssss2358
Two 15's? I dont think it'll be a bad thing, but that back corner of the wall behind the port needs to be made into a very nice curve, I'd say. It'll kill a bit of your volume, but I think it'd be worth it. Spend some time with some bondo/fiberglass and let it ride.
I dont see any reason why the port wouldnt be large enough. It seems to be plenty large enough.
I would put slightly more of a 45 on the bottom(although its almost already a 45...never hurts to have better air flow) and then find a way to curve the backside of the box. 5-6" from the rear of the port shouldnt give you issues either
Old 10-07-2010, 08:53 AM
0/11 sssss4519
1/2" all thread and i do plan on fiber glassing those two corners nice and smooth
resolve Vas/28.32 =
result of that +1
Old 10-07-2010, 08:37 PM
0/11 sssss4519
look good? need any changes?
resolve Vas/28.32 =
result of that +1
Old 10-10-2010, 09:46 AM
0/11 sssss4519
bueller.....
resolve Vas/28.32 =
result of that +1
SD3000 - New Heatsink - 4500W 14.4V muriloalvares General Car Audio Discussion & Questions 17 04-23-2009 01:13 AM
