OK. I need input and questions answered - Car Audio Classifieds!
Old 10-09-2010, 12:30 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Default OK. I need input and questions answered
Car: 01 Impala
Sub: AQ hd3 15" D2
Amp: AQ 2200
Box: 3.9 cubes using a 6" Aero port, before displacement with removable ports.
(1) 32HZ (1) 44hz
Plan on doing the 44 HZ one first
Plans: Sub back to the trunk lid and aero to the driver side. Will also test sub forward and aero to driver side as well.
Now, this is what I came up with:
44HZ
32HZ
My question is, is that enough port area? If not, what will result in it?
Another question, where should I put the port? Bottom right corner, bottom left corner, or where??
Old 10-09-2010, 12:31 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
If not, I'm just gonna go ahead and try a 4th order. So can someone design me one? 34"L x 17"H x 20"D if that's doable for a 4th order and a 15" HD3.
Old 10-09-2010, 12:40 AM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
i dont think that will be enough port area, but i dont think that its small enough to make an audible difference...i had a prob. w/ my sa8 using a 3in port and it wasnt enough and sub would bottom out super easy so i had to use a 4in aero for a SINGLE 8 crazy huh?...but it made the worlds difference....id try it with the single 6in aero 1st cuz u could always go bigger or add another
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 10-09-2010, 12:42 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
OK thanks bro.
Old 10-09-2010, 12:50 AM
0/11 sssss5305
Is this a fart box? Barely over 3cubes net will NOT make that sub happy for daily. And the suspension is too stiff for a 4th order.
Old 10-09-2010, 02:21 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
It's intended for both.... but mainly a fart box. You think I should give it 4 cubes after even with throwing 2k at it? I ask because I always though the smaller the box the more power can be thrown at it?
Old 10-09-2010, 02:26 PM
poundstone's Avatar
0/11 sssss1635
x2 look at what it is recommending for port and what you have calculated. i know its not off much but i would make it at least the minimum.imo
2011 and 2012 usaci streetbeat 2 world champ
2012 2nd iasca advnw1 and lightweight bassboxing
2013 usaci mod 1001-2k world champ
2013 second meca mod 5
2014 mwspl adv 2 world champ
2014 meca mod 4 world champ
usaci streetbeat 2 world record holder b and k
usaci mod 1001-2k legal world record holder
mwspl adv 2 world record holder
first 160 ever on fusing at headrest in meca
box input please! jimmay Enclosure Discussion & Design Construction Help 8 09-06-2010 09:57 PM
would like some input constantprojects General Car Audio Discussion & Questions 13 09-02-2010 10:04 AM
Please help with amp input!!! dadydolas General Car Audio Discussion & Questions 7 08-16-2010 12:12 PM
need input kingmade08 General Car Audio Discussion & Questions 16 04-11-2010 10:44 AM
Want some input on a new HU nismos14 General Car Audio Discussion & Questions 26 03-20-2009 08:20 AM
