Box rebuild (I need it louder) - Car Audio Classifieds!
Old 10-10-2010, 09:48 PM
0/11 sssssss20
Default Box rebuild (I need it louder)
My current box for my 2 re srx 12's is 4 ft^3 with 2 4in pvc ports tuned to ~32Hz. I'm giving them the rated power of 300w each. It hits the lows nicely but I would like it to be a bit louder and still keep my low end response. Got any tips on how to do this?
Old 10-10-2010, 09:51 PM
maverickdog8's Avatar
0/11 sssss2979
Try tuning a box just a little bit higher. 35-36hz.
Old 10-10-2010, 09:57 PM
use 2 6" ports and tune to 35hz
Old 10-10-2010, 09:58 PM
0/11 sssssss20
The recommended box is 3 ft^3 tuned to 35. I have been told it may be a little big. I thought about making a slot port box. Would I notice a difference between the 32Hz and the 35Hz? I really like the lows.
0/11 ssssss103
tune to 38-40hz with the same set up should still do good if not go to 5^3 tuned to 38 with same 2 4in pvc
Old 10-10-2010, 10:12 PM
0/11 sssss1330
Two 4" aeros is small, add more port area.
2010 Volkswagen CC
HRE Wheels | Nitto Tires | Solo-Werks
Ground Zero | Ampere Audio | Juicebox Battery | AudioControl | KnuKonceptz
Old 10-11-2010, 12:18 PM
0/11 ssssss103
4 4in pvc 16 inches long well get u tuned to 38hz in a 5^3 boxand louder too
Old 10-11-2010, 06:58 PM
0/11 sssssss20
I've also been told the box was to big. That 38 tuning sounds kinda high if I want to keep the low end.
Old 10-11-2010, 07:01 PM
FLAstrongman's Avatar
0/11 sssss1156
Feedback Score: 21 reviews
Not too big. I would go 5cu ft tuned to 35hz, a lot more port area and double the power.
Custom box builds for FL:
Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee, xx-wade-xx, traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
Old 10-11-2010, 07:18 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
erm 5ft^3 and double the power? for a 300rms rated sub built in china. im sorry but i totally disagree with you on this one.
SHABAM
what would be louder? newarkbeast973 General Car Audio Discussion & Questions 37 07-22-2010 12:00 PM
Want it louder. Will a different box help? westman995 General Car Audio Discussion & Questions 38 07-09-2010 05:55 PM
which would be louder? BASSLOGHEAD General Car Audio Discussion & Questions 17 01-18-2010 09:36 AM
Which set up would be louder? westman995 General Car Audio Discussion & Questions 19 12-05-2009 03:43 PM
What would be louder 6 15s or 4 18s theking General Car Audio Discussion & Questions 48 10-15-2009 07:55 AM
