Plexiglass /Lexan boxes - Car Audio Classifieds!
Old 10-22-2010, 10:36 PM
0/11 sssssss21
Default Plexiglass /Lexan boxes
How thick would Plexi or Lexan have to be,to at least equal the density/strength of 3/4 MDF?
Old 10-22-2010, 10:43 PM
0/11 ssssss400
You can use a thinner lexan to be equal to mdf. Although I use .93" lexan. There is a special glue if you build a box using ONLY lexan. Lexan to mdf just silicone.
<<<20 Hertz SEALED on the DASH.
Ohio Generators High Out Put Alternators
Old 10-22-2010, 10:50 PM
0/11 sssssss21
Is Lexan preferred over Plexi?
Old 10-22-2010, 10:55 PM
0/11 sssssss68
How does acrylic play up to plexi and lexan?
Old 10-22-2010, 10:59 PM
98AckCL23's Avatar
0/11 sssss9929
Plexi is a brand, like Kleenex is with tissues. Acrylic is the material. IIRC, Lexan is much preferred to Acrylic, due to better strength properties. But, it is also much more expensive.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 10-22-2010, 11:06 PM
0/11 sssssss21
Can these be cut easily like MDF,or do you need special tools,and say a prayer before cutting to avoid cracks?
Old 10-22-2010, 11:19 PM
0/11 sssss1411
I use a fine tooth blade to cut plexiglass at my work. it sands down easily like mdf does with a belt sander to get a nice edege on it - if you are janky with the cut -
have to realley abuse it to get it to crack when cutting. actually - ive only cracked a piece trying to run a screw in a hole I drilled too small for the size screw I was using. if you plan to screw in to the plexi - you gota use the right size drill bit - and counter sink if your using counter sink style screw heads
Old 10-22-2010, 11:48 PM
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
yes, acrylic is plexi, whereas polycarbonate is lexan.
both require a high tooth count, carbide tipped blade in order to cut without chipping the adjascent surface/s,... Best method I've found in cutting either material is to score the surface on both sides first with a max depth of 1/32"-1/16" in order to relieve the edge of "lift" that is inherent with cutting any material when a saw has a downward/upward stroke against the face,... make multiple passes after while increasing depth 1/8"-1/4" for each pass and you should be fine.
also, lexan is 10 times harder than glass, but scratches very easily and is susceptible to discoloration (yellowing) from u/v light
plexi is only 4 times harder than glass, but is much more scratch-resistent than lexan and doesn't discolor.
who wants a nudel ride?
Plexiglass Traxxstar504 General Car Audio Discussion & Questions 15 09-05-2010 08:21 PM
CNC Routing Etching plexiglass Ricoshay General Car Audio Discussion & Questions 11 05-06-2010 02:52 PM
Cutting plexi/lexan Boomintahoe Sound Deadening & Fabrication 5 04-08-2010 10:19 PM
Plexiglass question MeLykeLotion Enclosure Discussion & Design Construction Help 2 02-25-2010 05:56 AM
acrylic and lexan (polycarbonate) Nudels Tutorials & Quick References 0 08-15-2009 04:25 PM
