18" in an Impala - Car Audio Classifieds!
Old 10-24-2010, 02:50 AM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
Default 18" in an Impala
So i have been reading and reading trying to find the best way to do this.
Im trying to fit an 18" HD/psi reconed in an 04 impala but im not sure how to build the box. I tryed designing an enclosure that took as much of my trunk as possible. when doing a large build in a trunk. am i looking for as much airspace as possible? i really need some help with this. this is my first sub that is bigger than 12's and im not sure what to do. i want it to be ported and i will be running 2500w to it off a mojo 4kw @ 2 ohms....
Bewbs
Old 10-24-2010, 02:52 AM
0/11 sssssss48
ur gonna have to do sub up port back. bout the only way you gonna make it happen.
Old 10-24-2010, 02:53 AM
0/11 sssss4240
thats what i was thinking. but i dont think that the waves will make it over the box and into the cab . thats my problem
Bewbs
Old 10-24-2010, 02:56 AM
0/11 sssssss48
port back into the cabin. deaden the trunk as best you can. you might have some flex issues with the rear deck.
Old 10-24-2010, 02:57 AM
0/11 sssss4240
port facing cabin? or port facing liscense plate? still the issue on will the waves go over my box and into the cabin ok
Bewbs
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
Port Through the deck
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 10-24-2010, 02:58 AM
0/11 sssssss48
u have a model that seats fold down? i would port back facing cabin
0/11 sssss4240
port thru the deck would be a lil too much work. i would like to keep it stock and not cut things out
Bewbs
Old 10-24-2010, 02:59 AM
0/11 sssss4240
and no my sets dont face down. but who says i cant take the back cushion out.... ive thought about that then i thought why dont i wall it. i dont really want to wall it though i rather just build the box in the back of the trunk.
Bewbs
Old 10-24-2010, 03:00 AM
0/11 sssssss48
u can fit 35-36 wide 17ish tall and at least 3 deep. with a lil room to spare. gonna be a tight fit though.
Tags
18 inch, audioque, impala, spl, trunk
My 96' Impala SS KAPONE.SS Member Rides & System Pictures 30 05-20-2010 03:48 AM
SPL Impala sholiz General Car Audio Discussion & Questions 6 01-16-2010 10:01 AM
Two 15 Li D4 in 63 impala my63impala Build Logs 55 10-25-2009 04:22 PM
96 Impala SS driver sslumpin imp New Member Orientation 17 06-03-2009 05:41 PM
