Check these calculations for me guys - Car Audio Classifieds!
Old 10-24-2010, 07:39 PM
Beatdown337's Avatar
0/11 sssss1535
Default Check these calculations for me guys
Im attempting t design an enclosure for 4 fosgate p1 15's. Airspace requirements on them arent that large so it'll fit fairly easily. (2 cu. ft.) So tell me if you guys think im on the right path with this.
The box is 40 wide x 35 deep x 14 tall
Internal volume = 9.329 cu. ft.
Port is slot port running along the bottom. 26 wide x 4 high
so i did 27.5 x 4.75 x 9 length (factored in wood thickness) and came up with .680 cu ft port dispacements. Soooo.
9.329 - .680 = 8.649 total
then 26 * 4= 104. And 104 / 8.649 = 12.02 cu. ft of port area per sq ft.
So i think im on the right track the only thing is i was shooting for a tuning of about 32 hz. Am i close or way off. Thanks in advance for the replies
Jarvis
Old 10-24-2010, 07:41 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Factor in displacement of moofers...?
Give me the net volume, port area, and port length n i can tell u the tuning...
Louder. Lower.
Team Tupperware
Old 10-24-2010, 07:45 PM
0/11 sssss1535
volume = 9.329 before disp
port 26W x 4H x 9L (slot port along bottom)
Old 10-24-2010, 08:24 PM
0/11 sssss1535
And i wont worry about the woofer displacements rockfords p1 motors are tiny at best lol
Old 10-24-2010, 08:26 PM
0/11 sssss8346
Im going to assume that you didnt factor in around half of the port width as effective port length. I used 9.2 cubes then as the net volume and 11" long as the port length (effective port length, but then again, surfaces that the port's near could also act as port)
And you have 39.6127122696632Hz tuning
Louder. Lower.
Team Tupperware
Old 10-24-2010, 08:46 PM
0/11 sssss6981
Saturn is dee man
Old 10-24-2010, 08:48 PM
0/11 sssss8346
Originally Posted by GetLikeMe View Post
Saturn is dee man
*orders custom tshirt that says 'the man' on it...*
Louder. Lower.
Team Tupperware
Old 10-24-2010, 08:51 PM
0/11 sssss6981
hahahaha
Old 10-24-2010, 08:52 PM
0/11 sssss1535
So what would the port length have to be in order to make it a 32 hz tuning
Old 10-24-2010, 08:56 PM
0/11 sssss8346
21.5" effective port length with that port area and net airspace will get you 31.9Hz tuning.
Louder. Lower.
Team Tupperware
Need help with aero port calculations! Jacobbz206 Enclosure Discussion & Design Construction Help 25 03-22-2010 09:41 AM
Car guys check it out! BigC-Expo General Automotive Chat 26 03-13-2010 08:43 PM
Check this ish! BlackWaterOp Off Topic Chat 4 08-06-2009 12:02 AM
Check it out Florida guys toyota thundra Off Topic Chat 6 03-16-2009 07:27 PM
check this out!! boomn89 General Car Audio Discussion & Questions 4 10-03-2008 01:34 PM
