HELP! This is making NO sense! - Car Audio Classifieds!
Old 11-01-2010, 02:27 PM
0/11 sssssss13
Default HELP! This is making NO sense!
I am going to have an enclosure built tomorrow and the information that I have on the subwoofer is making absolutely no sense to me. I need someone that really knows what they are talking about to interject. I bought an eclipse SW8010 and the way they present the info is confusing. Rather than giving figures like "displacement" and "net internal volume" they simply give this info -
recommended internal enclosure volume - 2 cuft
tuning frequency - 33 hz
internal height - 18.5
internal width - 12.5
internal depth - 20
port opening area - 2"x12.5" (25 squared)
Port length - 28.5
I'm used to seeing sub requirements in a completely different way and I cannot make sense of it. I need to change the shape of the enclosure and retain the internal volume and tuning frequency but I am unable to extrapolate anything from the info above.
If it helps the TS parameters are
nominal impedance - 4 ohms
Voice coil DCR - 3.3 ohms
FS - 21hz
Qms - 5.25
Qes - 0.39
Qts - 0.36
Vas - 28 L
MMS - 356g
Xmax - 22mm
Dia/Sd - 347 cm2
BL/No - 20 Tm
1 watt SPL - 86 dB
Old 11-01-2010, 02:42 PM
Hertz5400LincolnLS's Avatar
0/11 sssss3029
20*12.5*18.5 = 4625 / 1728 = 2.677 ft^3 gross internal volume before port/woofer displacement
2.75*12.5*28.5 = 979.6875 / 1728 = 0.567 ft^3 port displacement (added 0.75 to width - assuming one wall of port is wall of enclosure and wood thickness is 0.75, this would make width 2.75 total)
2.677-0.567 = 2.11 - 2.0 = 0.11 driver displacement
Someone please correct me if I am wrong but this is what I made out of the figures given. **Fixed after SPY pointed out a mathematical error
SOLD TO: orangelss, SPY, 98GMC, MLyons-Jr (2x), laserred97gt, kmanian1, sotelomichael, dB-r_Electronics, EpicenterDesigns
BOUGHT FROM: SPY, fasfocus00, bones22, dbdragguy, kmanian1, TeamPSI (2x), 80inches, pioneer~saturn, sotelomichael, vic713, dB-r_Electronics, Lance_aka_64
Originally Posted by 80INCHES
just build the box and sit back and let the bass flex the $hit out of ur ride
Old 11-01-2010, 02:44 PM
bobbygilly's Avatar
Owner of UE
0/11 sssss6562
Feedback Score: 23 reviews
say your on 3/4 inch mdf
internal height - 18.5 + .75 + .75 = 20H 14W 21.5 deep tune it to 33hz with 25 square inches of port....thats what i get from it anyway
Team Unlimited Excursion
get low or die trying....
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
2.75*12.5*28.5 = 886.875 / 1728 = 0.513 ft^3 port displacement (added 0.75 to width - assuming one wall of port is wall of enclosure and wood thickness is 0.75, this would make width 2.75 total)
2.677-0.513 = 2.164 - 2.0 = 0.164 driver displacement
Right idea but your math is a little off.
2.75x12.5x28.5= 979.6875
/ CAAA Member #2 /
Old 11-01-2010, 02:46 PM
0/11 sssss3029
Ooops, you are right...I was even using a calculator. Not sure how that happened.
**Fixed it
Old 11-01-2010, 02:53 PM
0/11 sssssss13
Thanks guys. For some reason the way they presented it is totally backwards from how I normally look at the info. It was driving me nuts!
Old 11-01-2010, 03:04 PM
Benny33's Avatar
Hockey players, man...
0/11 sssss1616
I am confused as to why you found this difficult to comprehend.
2ft3 net
25in2 port 28.5in long
Yous just figures that out? All the hots ones is crazy!...And deh ugly ones too. - Toki Wartooth
Old 11-01-2010, 03:07 PM
0/11 sssss3029
2ft3 net
Maybe he didn't know how to do the calculations and work backwards? Last time I checked there are forum members with all different levels of knowledge on here. Ridiculing a new member is not the best way to retain them.
this doesn't make sense korey_hofer General Car Audio Discussion & Questions 0 08-22-2010 01:28 AM
I found a vid of Boxxy where she makes sense! madmat Off Topic Chat 29 10-05-2009 11:08 AM
i need help making it fit. RidnClean General Car Audio Discussion & Questions 34 07-15-2009 04:25 PM
Making Your Own RCA's worstenemy453 General Car Audio Discussion & Questions 22 03-27-2009 01:20 AM
does this wireing diagram make sense to anyone? aturcotte127317 General Car Audio Discussion & Questions 38 11-14-2008 04:24 AM
